Which Tires Yall Get???
Old Jun 21, 2001 | 06:23 PM
kazukun1230
I have a lowered 1990 Maxima and I have recently found out that my two front tires are going bald again. The last time I changed my tires was a year and a half ago and I am seriously wondering about what tires I should get. Do you all think that the alignments are just screwy and I have to fix that first. Do you think it's possible to get widder front tires..? If so what size? Anybody hit me back with any info. Thanks
Old Jun 21, 2001 | 08:13 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
HOw low is your Max???
the camber might be off thus causing the tires to bald fatser, just my guess...
Old Jun 21, 2001 | 08:42 PM
HoJo's Avatar
Ok first off there is this thing I like to call rotating the tires, I know this may be a new concept to you but it involves rotating the rear tires to the front. Anyway, YES GET AN ALIGNMENT DONE!!! after lowering the car the alignment will be off. I just had mine done and the front toe was way out, like .66 on the right and .53 (spec is around 0-.05) on the left(spec is around 0-.05). Kinda looked like this \---/ going down the street.
Old Jun 22, 2001 | 01:40 PM
kazukun1230
Thanks for the reply
Yeah I guess I'll get the alignements done...but after I get tires. My car has the Eibach pro kit which lowers the car about inch and a half. Anybody have inputs in what tires I should get. What size should I get if I want to get wider tires?
Old Jun 22, 2001 | 01:46 PM
HoJo's Avatar
First off how much are you looking to spend on tires, $200, $500? That makes a big difference. I'm assuming you have the stock SE wheels which are 15X6.5. The stock size is 205/65, if you want bigger 215/60 or even 225/60 will fit without the speedometer being off.
Old Jun 22, 2001 | 01:49 PM
DA-MAX's Avatar
What type of rims are you using??
if you're running 15's I'd say stay with the stock 205/65/15 size or maybe lower the profile to 205/60/15 you might also be able to do 225/60/15(wider), but I'm not sure if that might rub a lot , but for 16's you can do 215/55/16 or 225/50/16(being the widest)...use this page it'll help you out a little more--->
http://www.miata.net/garage/tirecalc.html
Old Jun 22, 2001 | 03:14 PM
Shugarhi's Avatar
Re: What type of rims are you using??
doubt this will help you, but i got...
225/45/17's Nitto Extreme Performance 455
Old Jun 23, 2001 | 02:24 PM
Quez's Avatar
I have 225's
I bought a pair of 225/60/15 Dunlop SP 5000 and put them on the stock rims... i'm lovin them. They look good and ride excellent... my rain traction is incredible. But listen... if you're car is lowered... you need to do some measuring or talk to some experts cause you may be pushin it by going wider with you wheelbase closer to the tire.
aw11power
Oct 10, 2021 04:57 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
