Injector additives
Old Jul 17, 2006 | 07:27 AM
Alex_V
Injector additives
I really want to put some lucas injector cleaner and upper cylinder lube into my tank, but I know our injectors suck ars and like to commit suicide easily. I thought the lucas stuff was cheap and was mainly oil and not detergants or harsh additives but Im still skeard.
Anybody use addtives with sucess?
~Alex
Old Jul 17, 2006 | 04:34 PM
cmachemer's Avatar
don't even worry about it
The only one I would recommend is Techron...ran that right after I bought the car (and then again every so often) as for others....I've tried others haven't noticed any differences (tried Gumout / Prestone / some generic brand)
Old Jul 18, 2006 | 03:55 AM
Maxima Man's Avatar
I use Techtron too its the best when matched with shell 93 baby !!!!!
Old Jul 18, 2006 | 08:08 AM
92 Max's Avatar
The only engine cleaner that I've had good results with is the Chevron Engine Deposit cleaner. I had a MR2 that always carboned up the valves and pinged. A bottle of this cleaner would stop the pinging for another 6 months.
Old Jul 18, 2006 | 09:40 AM
Alex_V
no love for lucas? hmm.
Ill try a bottle of techron I guess.
~Alex
Old Jul 19, 2006 | 05:42 PM
mountainmax's Avatar
"...but I know our injectors suck..."
Well, I don't think they really suck.... But I got 180,000 miles out of mine using regular doses of Techron (about every fifth or sixth tank). Now in my 1991 z32 tt I just had one roll over and die on me with 38k miles on it, and that does SUCK...but the Z does have "issues".
Steve
Old Jul 19, 2006 | 05:56 PM
goon9's Avatar
200,000 still original injectors
Old Jul 19, 2006 | 05:59 PM
Alex_V
I really just ment they are easily killed with additives. I know my 240 can stand up to alot more chemical abuse then the maxima injectors thats all I ment.
Ive had 3 maximas, one with 166K I knew all the owners (2 other then myself) had org injectors, the 186K looked like it did, and idk about the POS 217K parts car but it ran like garbage.
Im running all the 166K injectors in my 186K engine tho, it was running rough and swapping the whole rail helped alot and now it just sat for 5 months and is running a little sluggish with 18* base timing.
~Alex
Old Jul 21, 2006 | 09:48 AM
sanford7575's Avatar
Lucus Oil Injector Cleaner
I just ran a bottle of Lucas Oil injector cleaner into my '92 SE which was hesitating intermittently when accelrating from a dead stop.
I've run about 1 tank of gas through so far and the results have been better so far.
Question, do you guys use mosly 87, or do I need to run a higher octane?
Old Jul 21, 2006 | 10:21 AM
Maxima Man's Avatar
I use 93 Shell and I run techron alot.
Old Jul 21, 2006 | 02:35 PM
internetautomar's Avatar
mod or sell?
The VE is recommended to run a minimum of 91.
it will run on 87, but if you have a functioning knock sensor it will retard the timing to compensate for the lower octane gas when it detects detonation
Old Jul 21, 2006 | 08:52 PM
Alex_V
I usually use 87, but I want to advance my timing and start running premiuim and see if it makes a diffrence.
~Alex
Old Jul 21, 2006 | 09:01 PM
ColombianMax's Avatar
I use Valvoline injector cleaner and omg a big difference you guys should give it a try...from all the injector cleaners I've tried, Valvoline has done the most for my car.
Old Jul 21, 2006 | 09:17 PM
Alex_V
If it doesnt liven up after I use the rest of the techron and seafoam it Ill try that. I wonder if advance has some too.
~Alex
Old Jul 25, 2006 | 12:27 AM
Camfantasy's Avatar
iv used the lucas at the last 3 or 4 oil changes and my injectors are still goin strong
Old Jul 25, 2006 | 09:33 AM
I've used the Lucas injector cleaner before and didnt really notice much difference and also I've heard from people at work that its nothing but the brand..other than that its no good. Now if you talk about the oil stabilizer thats another story. Anyone agree with that?
Old Jul 26, 2006 | 11:23 AM
Camfantasy's Avatar
what are yalls opinions on the restore oil additive stuff?
Old Jul 26, 2006 | 01:18 PM
Sgibb's Avatar
I just used the techron fuel system cleaner with a tank of premium the other day and it seems to be working
Old Jul 26, 2006 | 02:23 PM
sublunary's Avatar
just to be safe i try not to use injector cleaner often but i was getting some put-put out of the exhaust and thought an injector was going. i ran lucas through and the performance came back and put-put gone. so thats my experience at least
Old Jul 27, 2006 | 05:22 PM
Jon94SE's Avatar
Techtron worked pretty well for me
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Fbana41
Aug 29, 2016 12:18 PM
BkGreen97
Apr 2, 2016 05:47 AM
