alt problems
Old Aug 4, 2006 | 06:04 PM
SurraTT's Avatar
HR Swap Pioneer
alt problems
ok so for a long time, my brake and batt light have been on, so thats Altnator??
took it off, tested fine,
tested on car, fine
got a used ve alt, put it on today
tested off the car great
its on, and lights are the same,
ive looked at fuses n all,
cleaned terminals
idk what to try now
also my orig alt was like 25F the used i just got is like 24E
same p/n on there and 95 amps
Old Aug 4, 2006 | 06:09 PM
Greeny's Avatar
¯\(°_o)/¯
Have you checked the big fuses[fusible links] in the box by the battery?
Old Aug 4, 2006 | 06:11 PM
SurraTT's Avatar
HR Swap Pioneer
yes, kinda none said anything about chargine or anything
ill go look right now
Old Aug 4, 2006 | 06:15 PM
Greeny's Avatar
¯\(°_o)/¯
It's the small box..
SurraTT's Avatar
HR Swap Pioneer
they are fine
edit, the one beside the battry?? ign switch and stuff like that, headlight fuses?
the car is def chargine, if not i would be dead in no time with my system. actually my headligjhts done even dime, so it must be in top shape
Old Aug 4, 2006 | 06:16 PM
Greeny's Avatar
¯\(°_o)/¯
What voltage are getting at idle?
Old Aug 4, 2006 | 06:17 PM
SurraTT's Avatar
HR Swap Pioneer
let me go cheack,, i was going to when i was out there, o well
Old Aug 4, 2006 | 06:22 PM
SurraTT's Avatar
HR Swap Pioneer
13.5 at idel same as old ALT
Old Aug 4, 2006 | 06:24 PM
Greeny's Avatar
¯\(°_o)/¯
13.5 at idle is good....
Old Aug 4, 2006 | 06:26 PM
Greeny's Avatar
¯\(°_o)/¯
Have you experienced any other symtoms besides the lights??
Like hard starting/dead battery???
Old Aug 4, 2006 | 06:27 PM
SurraTT's Avatar
HR Swap Pioneer
ya, nothing but problems hear latley
brakes squeeling
wheel stud broke off.....
its just getting on my nervs
mo fos at nissan wont hook it up to the scanner, for some damm reason
Old Aug 4, 2006 | 06:30 PM
SurraTT's Avatar
HR Swap Pioneer
no,
other than, when i 1st got the car, its was completly dead
so i jumped it off, and it charged up and is ok, like 2 weeks after having it, the batt and brake light came on
my fluid it ok, brake pedal switch is ok, e brake is ok, brake lights work, fuses r ok, alt is plugged up ok
idk
SurraTT's Avatar
HR Swap Pioneer
no,
idk
Old Aug 4, 2006 | 06:32 PM
SurraTT's Avatar
HR Swap Pioneer
woops, the org is moving so damm slow, i chant stand it, i have to have it open in like 5 windows to go through the forms
anyone else experence slowness?
Old Aug 5, 2006 | 07:45 AM
SurraTT's Avatar
HR Swap Pioneer
well this morning, i pulles the 10amp alt fuse, and the battry lihgt was on bright, the brake light was completly off
i also noticed the main 45 amp fuse looked kinda black, but it wasent blown, ima get one today
Old Aug 5, 2006 | 07:37 PM
internetautomar's Avatar
mod or sell?
I'd be looking at the grounds and start checking wires and connections.
BTW a malfunctioning regulator can trigger the lights and still charge just fine
ask me how I know
Old Aug 13, 2006 | 08:56 PM
BOOSTonU's Avatar
ive been having a dead battery every morning...and ive checked the alternator and its fine.....its really pissin me off
Old Aug 14, 2006 | 05:48 AM
mod or sell?
which means you have a current draw.
start pulling fuses one at a time with a meter attached between the battery and battery cable.
the fuse that changes the meters reading is the circuit with the draw
Old Aug 14, 2006 | 08:26 AM
Jon94SE's Avatar
If you're ever suspicious of a fuse, check it with a meter even if it doesn't look blown. Shortly after I bought my car I lost my taillights,dashlights, and my corners. I checked all my fuses twice and couldn't find any blown ones, so I started digging through wires and taking the dash apart and finally decided to check the taillight fuse again with a meter, and sure enough it was bad even though it looked fine.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
