Erattic Idle
Erattic Idle
I have an erattic idle on the RPM guage when the AC is on. It seems as though the clutch is engaging when this happens but it just does not seem normal. Also, I am getting periods when the air isn't as cold as it should be. Is this a sign that the compressor is goin bad. I do hear bearing chattering when I accelerate, but a guy told me that all Nissan compressors do that.
He said to just drive it.....
Yes,
The eratic idle starts after the compressor is engaged, but the funny thing is that it doesn't happen all the time. If I am sitting at normal idle with the compressor on, the idle will increase and then drop eratically as if it is about to cut off. Can I replace the clutch without buying the entire compressor?
Don't know what engine you have, but there is an idle up for the a/c. On the SE engine the Idle air control has a FIDC or FICD solenoid on it that, when activated with the a/c increases the idle. Perhaps this solenoid is intermintant.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
