control arm replacement
Old Aug 12, 2006 | 09:02 PM
alextothestars's Avatar
im replacing my passenger side control arm because the bushing is practically gone (from oil...not sure if its from oil changes or the oil seal). it makes the "bang, ting" sound whenever i drive over any dip or bump, likes to steer a bit in the wrong direction at shifts/messes up my traction...sometimes trying to throw me off the road when i barely turn at 80mph+ speeds (of which i refrain from driving at now!!).
anyhow, i have my haynes manual and ive surveyed the actual situation underneath my car. i went ahead and purchased the control arm. seems like all i need to do is remove the bolts/nuts, replace part, and then tighten a bit, lower car, and then tighten bolts to recommended torque.
is there anything that complicates this situation or any special tools i might need? haynes is an awful repair manual and they always leave out the small, important details!
Old Aug 13, 2006 | 05:37 PM
Governor's Avatar
The brass bushing on the inside of the rubber bushing often seezes up and u will have to dremel it off..good luck
Old Aug 13, 2006 | 09:12 PM
MaximaV6's Avatar
Lower control arm? http://www1.autozone.com has a site and it provides the steps in the steering and suspension section. I'm sure there are better directions but I'd need to google. Perhaps, there is more detailed info in one of the faq sections?
Old Aug 14, 2006 | 03:10 AM
andos06's Avatar
yeah it's a great site check it out
Old Aug 15, 2006 | 07:04 PM
wrkllc's Avatar
After changing the control arms go and get it realigned as the new control arms will change the alignment quite a bit. Good luck.
Old Aug 17, 2006 | 02:50 AM
yeah, i had it aligned a few months ago and it didnt do a damn thing because that passenger side likes to move in/out a little depending on where/how ive been driving. not a lot, but enough for me to notice a difference in the performance/noisiness.
Old Aug 18, 2006 | 04:27 PM
hmm; everything was real easy (got the SUPERsized socket wrench out) until i tried to undo the 3 nuts that hold the control arm and ball joint together. anyone have a good opinion on how to get them to ease up other than using wd40 or having a torque gun?
Matt93SE
May 24, 2019 02:58 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
maxocar
Aug 21, 2015 12:57 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
