flywheel compatibility question
Originally Posted by -shock211-
Will a 4th gen flywheel work on a VE?
It fastens with 8 bolts like a VE but will the ring gear line up to the starter?
Anyone know?
Anyone know?
I'd be more worried about balance.
I didn't mention it but I'm referring to the Fidanza lightened flywheel.
The flywheels are the same diameter and the VQ flywheel is weighed at 1lb more than the VE according to Fidanza. The ring gear teeth are the same according to the measurements I took. All I need to know is if the ring gear will line up evenly with a 3rd gen starter.
Brian, put down the crack pipe.
you're changing the flywheel, which is balanced assembly, and putting it on an engine, which is another balanced assembly.
it's just like bolting on a lighter crank pulley or a lightened stock crank.
Won't fit. Fidanza has diff p/n for both.
Anyone know?
Anyone know?
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
