Rear well rust.
Old Aug 29, 2006 | 08:52 AM
berts689's Avatar
Rear well rust.
Well just last night a noticed dampness on my back left seat so i pulled it and found a medium sized rust hole leading directly into the well. Its not so big that it'll mess with the strut mounting. how would igo about fixing this? ive already took a wire brush to it but i want soemething permanent, i have some silicon tape covering it with sum duct tape reinforcement. Should i take it to midas weld?
Old Aug 29, 2006 | 08:59 AM
89blackse's Avatar
"and falling like a rock"
YOU NEED to check your rear seatbelt brackets to make sure they are not bolted into pure rust, it’s a known issue with 3rd gens.
If however your rust is like mine, you can clean it up with a dermal buy some sheet medal prime the medal prime the cleaned/stripped rusted area, place the sheet over the hole and pop rivet it into place.
I also used some heavy duty poly sealant to fill in around the cracks.
Prime everything again, and spray a coat of underbody spray in your wheel well
OH and if you think you only have one rust whole in your well, think again, take a hammer and poke around to find them all. Takes about 2 hours to do several holes.
Old Aug 29, 2006 | 09:04 AM
berts689's Avatar
i took out my seat belts about a month ago to install an amp and it seemed fine. But yeah the surrounding metal on the rust seems like crap. And when i bought the car there was already underbody coating in the wells and on the under carriage. maybe just a missed spot? im gonna go at it with a hammer like you said.
Old Aug 29, 2006 | 09:26 AM
internetautomar's Avatar
mod or sell?
it may be covered under the recall.
Old Aug 29, 2006 | 10:05 AM
89blackse's Avatar
maybe. but if his stealerships are like they are in Kentucky they will tell him to go forth and multiply.
I love this generation of maxima but some things arent worth fixing/dealing with nissan.
Heat up some
http://forums.maxima.org/showthread.php?t=347576
Old Aug 29, 2006 | 10:08 AM
mod or sell?
Heat up some
that's why you call nissan and the NHTSA
Old Aug 29, 2006 | 10:13 AM
89blackse's Avatar
Well, you are 150% correct. If you plan on having people in your backseat (that you like) then go out of your way to get this done...
Myself? I have way too much **** in my backseat to fit people into so it doesnt matter.
Old Aug 29, 2006 | 07:03 PM
viper92086's Avatar
i doubt it wil be covered under recal... cause my friend brought his back not to long ago and the dealer gave us all the bull**** like it shoulda been fixed years ago etc etc
Old Aug 29, 2006 | 07:08 PM
mod or sell?
that's why you call in the big dogs
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
