Spoiler removal/replacement
Old Sep 4, 2006 | 06:20 PM
4togrfr's Avatar
The left side of my rear spoiler has broke loose from the trunk. I originally figured it was simply bolted though the trunk, but that is apparently not the case. I would like to remount the spoiler, but need to get it off the trunk first to fix it. Can anyone give some insight how the stock spoiler is removed? Thanks.
Mike Overton
1990 SE
Old Sep 4, 2006 | 09:04 PM
Hectic's Avatar
remove trunk liner, undo four 7mm bolts, unplug wiring and take it off carefully.
Old Sep 4, 2006 | 09:05 PM
Cliff Clavin's Avatar
Way out West
unless you glue it down, you probably won't be able to do much. The material that the spoiler is made of just warps itself and the screws will only tighten so much.
Old Sep 4, 2006 | 09:15 PM
Duckman540i's Avatar
VE Powah!!!
What is the best glue to use? Nobody replied in the other thread.
I will either use:
#1 2400 PSI Epoxy
#2 Gorilla Glue
What is better to hold the spoiler down? I'm gonna apply either one, & let it sit overnight, with C-clamps.
Thanks.
Old Sep 5, 2006 | 03:13 PM
andy044's Avatar
RWD bolt-on conversion?
someone on here used LiquidNails from Home depot
with good results
either way>
make sure both surfaces are roughed up a bit then
make sure surfaces are VERY clean and dry.
a lilttle searching action wouldve help you tons
Old Sep 5, 2006 | 08:09 PM
rmdl51's Avatar
White_Shadow
Hi! I have the same problem And someone suggest me to put some double sided tape but didn't work, it came off after a few days, I've looking for the original clips that secures the spoiler to the trunk but I haven't had any luck, I wish someone could share information about where to get this clips.
Old Sep 5, 2006 | 08:41 PM
synoptic's Avatar
My Spoiler has done the same thing. There was a thread on here a while back where the guy actually filled the wing with a gap filler and secured new bolts into that and mounted it to the car again (i think that is what he did anyway but dont quote me)
Old Sep 5, 2006 | 09:31 PM
Gun5's Avatar
just go spoilerless or get a lip
Old Sep 6, 2006 | 12:24 PM
Majik's Avatar
I am interested in the outcome for this fix as well, my left side on my 90 SE is doing the same thing...please provide pics of the steps you took...provided you were successful please. Thanks...
Old Sep 6, 2006 | 01:11 PM
bhunter's Avatar
I fixed mine by filling the holes where the screw studs were in the center section with silicone adhesive and then screwing in spiral sheetrock anchors until flush and then let it set and cure overnight. Then the next day after cleaning all surfaces I screwed bolts into the sheetrock anchors through the trunk and glued the outside edges down with more silicone adhesive and set sandbags on each end and left it overnight. Stuck great.
Old Sep 6, 2006 | 06:08 PM
VE Powah!!!
with good results.
Vansskaterfreak used the Liquid Nails. Also I did search alot.
Old Sep 7, 2006 | 05:37 AM
Majik's Avatar
Did the sheetrock screw anchors need to be trimmed or did they fit in full length?
Old Sep 7, 2006 | 07:55 AM
bhunter's Avatar
They easily fit full length.
Old Sep 7, 2006 | 08:31 AM
Jon94SE's Avatar
I also have this problem, I'm sure apoxy would work just fine that's what I'm going to try
Old Sep 7, 2006 | 12:15 PM
Majik's Avatar
Cool...thanks for the information!!
Old Sep 7, 2006 | 05:41 PM
4togrfr's Avatar
Thanks everyone for the reply's. I believe I will try reinstalling the loose studs into the spoiler with an epoxy resin.
Mike
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
