Lack of low end power
Old Sep 6, 2006 | 10:58 PM
mszilves's Avatar
I find when the car is cold, it pulls like a champ, but when it warms up, it hesitates and really has a lack of power up to about 3000RPM. It always idles fine. To add to it, the problem is intermittent... I'd say about 80% of the time.
I have new plugs, new fuel filter, air filter, oil filter/synthetic, recently replaced left VTC, left exhaust studs. Two month old battery, alternator, starter.
The problem has been around for a while now, it's really annoying, as I typically don't rev my engine too high, so the lack of low end torque and power is really starting to bug me. Anyone have any ideas? Could it be the ignition coils?
Old Sep 7, 2006 | 05:02 AM
Greeny's Avatar
¯\(°_o)/¯
Replace your knock sensor....
Old Sep 7, 2006 | 11:46 AM
Pearl93VE's Avatar
I can has?
Could a Knock sensor be the culprit of bad gas milage? I also notice on hot days the car just doesn't have that low end torque off the line like it does say... early in the morning or at night. I recently got my transmission replaced about 3000 miles ago and sometimes feel a surge, or sudden vibration coming from the front of the car when going up hills, or even sometimes when at a consistent speed. Could this be a faulty knock sensor?
Thanks in advance
________
Personal Vaporizers
________
Vaporizer affiliate
Old Sep 7, 2006 | 11:59 AM
Greeny's Avatar
¯\(°_o)/¯
Thanks in advance
That sounds like maybe you needs a tune up..
Old Sep 7, 2006 | 12:17 PM
91-Maxima-SE's Avatar
Any advice on replacing the knock sensor on a VG? I know where it is and everything, but is there any easy way to get it out?
Old Sep 7, 2006 | 12:54 PM
Pearl93VE's Avatar
I can has?
94 VG
Just did a tune up less than a thousand Miles ago. Everything and then some. Oil Change, Cleaned EGR, Throttle Body, Custom CAI, New o2, All usual tune up parts including filters, plugs, and wires etc. Checked for exhaust leak found none. Seafoamed, Marvel Mystery Gas Additive. All same size tires, recent alignment job, new transmission. Running out of things that could be it here. Just can't find why I'm getting so poor of gas milage. Pulling my hair out trying to figure out it...
________
NB50
________
WEBSITE HOST
Old Sep 7, 2006 | 01:42 PM
VEvolution's Avatar
I miss my VE
Hey could a knock sensor still be bad if theres continuity in the plug? I know the ECU might not throw out codes..
94 VG
How much MPG are you getting and whats your driving style?
Old Sep 7, 2006 | 01:44 PM
Jeff92se's Avatar
I'm needing a caw
O2 sensor?
Old Sep 7, 2006 | 01:51 PM
Cliff Clavin's Avatar
Way out West
first thing you should do is check for codes. This isn't a guarantee because sometimes a sensor could be bad and it still doesn't show up. It is a simple way to start. Dig through the stickies and you should be able to figure this out.
lack of power, especially when the car is warm is often the knock sensor. When my KS was going out, after about 45 minutes of driving, there was a noticeable decrease in power.
Jeff mentioned the o2 sensor, which usually hurts power and fuel economy.
hesitation on the VE engine is usually caused by coil packs. Either one or several might be cracked or internally malfunctioning.
Old Sep 7, 2006 | 02:46 PM
mszilves's Avatar
Thanks for all the good info guys... it does look like it's the knock sensor. I have disconnected it to test (I'm running 92 octane so I should be safe from knocking), and it does feel like a noticeable difference in power, especially in the low end. I'm gonna leave it disconnected for a couple of days just to make sure. If I do need to replace it, is it pretty easy, or do you need to take the intake manifold off (I really hope not)?
Old Sep 7, 2006 | 02:48 PM
Jeff92se's Avatar
I'm needing a caw
Upper and lower manifolds have to come off. You'll choke when you price out the lower manifold gaskets.
Old Sep 7, 2006 | 03:13 PM
VEvolution's Avatar
I miss my VE
I heard it can still knock if you use the right gas
Old Sep 7, 2006 | 04:05 PM
Pearl93VE's Avatar
I can has?
94 VG
Got a new o2 VERY short while ago, I'll probably take it to autozone or something and try to get it to throw some codes. Hmm.... Think I'm going to gut my catalytic converter as well...
Also, I don't drive very hard at all, pretty casual usually but I'll occasionally get on it if I'm merging or something. Gas Milage is around 270 to a tank city/highway mix.
________
*** white
________
Depakote Attorneys
Old Sep 7, 2006 | 04:58 PM
Ok, so I guess not then...
Old Sep 7, 2006 | 05:44 PM
Greeny's Avatar
¯\(°_o)/¯
There is no easy way to get to it...It's a very small area to work in...
Unless you are sure it is bad,then don't mess with it...
Old Sep 7, 2006 | 06:08 PM
92 Max's Avatar
Here's a link to a good knock sensor replacement writeup. It shows what you're up against to replace this knock sensor. After reading this the lack of power might not be as bad as you first thought. http://www.4dsc.com/articles/drivetr...k_sensor.shtml
Ok, I do know its bad, but I was thinking of just getting another wiring harness and KS and zip-tying it to a stationary hose or something.
Thank you!
Old Sep 7, 2006 | 08:41 PM
maximagician's Avatar
what should a ve k.s read?mines 0.555 m ohms on a digital multimeter
Old Sep 7, 2006 | 09:42 PM
mszilves's Avatar
The knock sensor looks expensive to replace due to the labor involved. Anyone know a ballpark price to get this done at a shop?
Old Sep 7, 2006 | 09:58 PM
Alex_V
Uh yea....dont! It will loose power and its really bad for the environment. Its wont gain you any power and its illegal. Just leave it as is unless its colgged. Only then should you gut it, but get a new one. I did on mine since it was clogged (smelled like rotten eggs) and Im definitly down on some low end power.
~Alex
Old Sep 8, 2006 | 10:29 AM
Pearl93VE's Avatar
I can has?
~Alex
Well I'm just trying to figure out why I'm getting bad gas milage. Hmm, You lost some low end torque on it? Hmm... doesn't it just let the exhaust flow more freely?
________
OUTDOOR FORCED
________
Bondage Webcams
Old Sep 8, 2006 | 10:34 AM
Greeny's Avatar
¯\(°_o)/¯
Gutting/removing the cat will NOT increase power at all,infact it will decrease power..Modern engines are designed to need some exhaust back pressure to perform at their best.....
You probably need a new o2 sensor and/or have a bad injector or 2...These problems are the leading cause of poor gas mileage for these cars....
Old Sep 8, 2006 | 10:40 AM
Jeff92se's Avatar
I'm needing a caw
Gutting cat = ricer exhaust sound + now you get to buy a new one to replace the one you just ruined.
Old Sep 10, 2006 | 08:44 AM
ebaker's Avatar
Is there a way to bypass the knock sensor? I remember something about using a 500K resistor.
Old Sep 11, 2006 | 04:39 AM
internetautomar's Avatar
mod or sell?
470k ,
Old Sep 12, 2006 | 02:27 AM
ColombianMax's Avatar
hmm, I think I want to replace my KS..are there any write ups for that since I only saw the one for the VE?
Old Sep 12, 2006 | 10:03 AM
VEvolution's Avatar
I miss my VE
Im pretty sure the idea is just about the same..
Old Sep 12, 2006 | 12:05 PM
mod or sell?
the VG has it behind the rear exhaust manifold.
Old Sep 12, 2006 | 12:14 PM
89blackse's Avatar
"and falling like a rock"
what?! are you serious. I was thinking of replacing that on my 89...
Old Sep 12, 2006 | 12:22 PM
Greeny's Avatar
¯\(°_o)/¯
Old Sep 12, 2006 | 12:39 PM
hmm, that doesnt seem to bad now does it?
Old Sep 12, 2006 | 12:51 PM
Greeny's Avatar
¯\(°_o)/¯
Says the man with leaking tranny seals...
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
