Hub Dilema
Hub Dilema
I need a wheel hub really badly, my front left is banging
really badly now, when I replaced the wheel bearing up there I noticed that the hub was chewed up pretty bad where it fits into the bearing. I cant seem to track down an ABS hub for it, so my question is can I run a non ABS hub there or will it simply not fit the same at all and if I could run the non ABS hub is there a way to dissable the ABS system for all four wheels so I don't run into trouble when I slam on the brakes?
I don't see no reason why you couldn't run a non ABS hub. The ABS system will automatically disable it self once you start rolling (ABS light will turn on) because the system will not see that wheel. With the ABS system disable there's nothing to fear if you slam on the brakes.
yes you can and like I posted in your FS thread it doesnt have to be from a manual...just from a VE.
Here is what you need to do if you want to keep your ABS. Take the new non ABS hub and assy. down to the machine shop and have them swap the good non chewed up hub into the ABS knuckle while they are doing the bearing so you can keep your ABS. Unless your knuckle assy is chewed up as well.
The only difference in the ABS and non ABS is the knuckle because the ABS knuckle has the mounting holes for the ABS sensor so you can use your knuckle from the ABS car if its not messed up.
ok thanks everyone, and yeah michael the only reason I was thinking the 5spd/auto thing mattered is someone told me the different transmissions had different hubs or something to that effect a while back.thanks for the help I can't wait untill the front of my car is quiet again!
James92SE
142
Jan 2, 2024 09:23 AM
Andy29
Sep 29, 2015 05:32 AM
londonflu
40
Sep 25, 2015 09:11 AM
