car vibrates when in reverse or drive gears
Old Sep 27, 2006 | 11:20 AM
ArcticDC5's Avatar
My friend's 3rd gen auto w/ 87k is doing some strange thing. If its engaged in either reverse or any of the drive gears, it will start vibrating - almost seems as if its missing a cylinder. I doubt its ignition related since it would be acting up while in park or neautral.
I drove the car and it drives and shifts fine minus the vibrations its causing. I am guessing its transmission related and maybe a torque converter gone bad???
Old Sep 27, 2006 | 07:43 PM
internetautomar's Avatar
mod or sell?
look for a miss anyway.
it's easy enough to check.
also check your motor mounts
Old Nov 15, 2006 | 12:25 PM
2Legal4Me's Avatar
fuel injectors or maf sensor maybe?
Old Nov 15, 2006 | 05:45 PM
vansskaterfreek's Avatar
my girlfriends 2000 altims SE does that... it has 175k miles on it...... it feels like the idle gets too low in gear.......
Old Nov 15, 2006 | 11:03 PM
ColombianMax's Avatar
Low tranny fluid?
Old Nov 16, 2006 | 05:38 AM
gregoryin07's Avatar
You might have to change your spark plugs or wires check them.
Old Nov 16, 2006 | 06:38 PM
Originally Posted by ColombianMax
Low tranny fluid?
s he does have VERY low fluid, but the fluid has never been changed........ it is almost black... im thinking of adding lucas... but im not sure if the lucas will even mes it up with 175k on the original fluid..
Old Nov 16, 2006 | 07:33 PM
Chris Gregg's Avatar
Get Off My Lawn
Ouch. Sounds like it's burned up. Could be due to low fluid. Might try to replace fluid and install some Lucas. Might get some more time out of the tranny.
Old Nov 16, 2006 | 11:35 PM
You sure about replacing fluid?...wouldn't that just = replace tranny sooner than necessary? could probably run on that black original fluid a few miles more before it fully dies, Rather than killing it faster with new fluid.
Old Nov 17, 2006 | 02:56 PM
motionman's Avatar
if it's vibrating on reverse or drive it's likely that your car is going to hesitate even more when you accelerate. i suggest that your fuel system is messy, but most likely your fuel injectors. your best bet is to buy fuel additives like a bottle of STP fuel system cleaner and put it in your gas tank the next time you refill gas. then after at least 1 or 2 days it should be fine.
Old Nov 18, 2006 | 06:11 AM
thats what im afraid of..... i am NOT gonna put new stuff in...... but i was debating on adding a bottle of lucas... but that even might mess it up....
Old Nov 18, 2006 | 04:17 PM
mod or sell?
if your trans is just starting to slip, then change the fluid you won't make it any worse.
I improved my old sable's tranny by adding a couple bottles of lucas to it. still slipped, but at least it didn't bang anymore
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Trin1j23
Aug 12, 2015 08:31 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
