occasionally shaking
Old Oct 4, 2006 | 08:19 AM
yaofch's Avatar
For a 93 Maxima GXE with around 95,000 miles:
Recently I just noticed some occasional shaking while driving at 40~50 mph. I don't know exactly where it comes from, but I can feel it on the steering wheel and the throttle and it seems coming from the front wheels. The shake is pretty strong and only lasts about 1 or 2 seconds. This only happens probably once in a week. By the way, new spark plugs, wire set and four tires (balanced) were just put on. So what sign could this be? Thanks.
Old Oct 4, 2006 | 09:35 AM
mszilves's Avatar
If your tires are balanced, it's possible that it's the right CV shaft support bearing. I had a similar problem with mine, and found that the bearing was pretty much toast. It will likely start as a small shaking, and get progressively worse as the bearing wears out.
Old Oct 4, 2006 | 11:39 AM
yaofch's Avatar
Thanks.
I think it's time to replace those drive axles -- actually they are in bad shape with toren cv boots.
Old Oct 4, 2006 | 01:57 PM
Jon94SE's Avatar
zilves, where exactly is this bearing you're talking about because i've been having some shaking problems lately pretty bad, I originally thought it was the driver side wheel bearing but i already replaced that and still no dice
Old Oct 4, 2006 | 05:25 PM
Greeny's Avatar
¯\(°_o)/¯
Old Oct 4, 2006 | 06:44 PM
yaofch's Avatar
I guess this the bearing mentioned by zilves:
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
Bonka
Sep 14, 2015 11:18 PM
