weird noise, oil leak & exhaust
Old Oct 4, 2006 | 09:43 AM
rmdl51's Avatar
White_Shadow
Hello!
I have a few questions on different matters, but I think is better to resume all in one thread:
1.- I have a knocking sound that (looks like) it comes from the front wheels, it only happen when I hit the gas, example, I start the car, reverse to get out the garage, drive until the first red light and everything ok, but then green light I hit the gas and I hear: “cluck-cluck----cluck-cluck-cluck” and then no more noise until I completely stop and accelerate again. What could it be? Ball joints?
2.- A few months ago when changed my spark plugs find out that has a little amount of oil on it (at the edge) doesn’t seem to be getting into the combustion chamber, but not sure, put on new spark plugs and just checked a few days ago and again it has a little bit of oil, so I guess I have a leak but I have no idea where to look for it, I don’t seen to be loosing a lot of oil because dipstick shows good level, leave a white blanket on the night at bottom of my car and no leaks. Any suggestions?
3.- Last one guys. I have an exhaust leak, you know I have this rattle noise at the bottom of my engine that drives me crazy (you can hear my car 100ft away) and instead of fixing it I rather upgrade to the warpspeed Y-pipe, but not sure if this will really fix my problem, or is it better to change the whole exhaust line? What would you recommend?
Thanks a lot!!
Old Oct 4, 2006 | 01:59 PM
Pearl93VE's Avatar
I can has?
Originally Posted by rmdl51
1.- I have a knocking sound that (looks like) it comes from the front wheels, it only happen when I hit the gas, example, I start the car, reverse to get out the garage, drive until the first red light and everything ok, but then green light I hit the gas and I hear: ?cluck-cluck----cluck-cluck-cluck? and then no more noise until I completely stop and accelerate again. What could it be? Ball joints?
Hmm, Does your car ever jitter or vibrate on the front end as well? I know my CV Axles are crap and I get a loud clicking coming from my drivers side front wheel. I would suggest taking a look at those.
Sounds like your manifold studs are broken...
________
Free x rated movies
________
Coach purses
Old Oct 4, 2006 | 02:34 PM
rmdl51's Avatar
White_Shadow
Yes, it vibrates in the front end sometimes but only when idle on P, never on D or R. but someone told me the idle vibration was due a broken engine support. I don't really know
Old Oct 4, 2006 | 04:44 PM
Maxima Man's Avatar
mabey you cat heat sheild is viberating ?...
Old Oct 5, 2006 | 10:59 AM
rmdl51's Avatar
White_Shadow
what shield do you mean? can I take a look at it by going under the car? you think this has something to do with my third question?
Old Oct 5, 2006 | 11:22 AM
Greeny's Avatar
¯\(°_o)/¯
The cat heat shield is attached to the body of the car over the cat converter..It could be vibrating..
IMO i think your vibrating noise is a broken flex section..
kjlouis
Oct 3, 2015 05:29 AM
dcam0326
Sep 7, 2015 07:26 AM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
