SE Rear Brake proportioning
Old Oct 5, 2006 | 03:30 PM
mszilves's Avatar
Does anyone know if the rear load sensing valves (used to aid brake proportioning on the rear under heavy rear axle load) need to be adjusted if the car is lowered?
My car has a fairly aggressive drop on Sprint springs (2" front and rear), and I'm curious if that affects the brake bias? If so, does anyone have any tips, or has anyone actually done any adjustment?
Old Oct 5, 2006 | 04:53 PM
internetautomar's Avatar
mod or sell?
I'm absolutely positive that lowering does affect it.
Just no clue how it affects it exactly, but probably the same way having a load in your trunk does.
I believe (totaly theory) that the lower it is (whether by spring or load) it INCREASES the pressure to the rear brakes
Old Oct 5, 2006 | 05:07 PM
Greeny's Avatar
¯\(°_o)/¯
I have not noticed any different braking characteristics from my car after dropping it..
Old Oct 5, 2006 | 06:55 PM
mod or sell?
that just means your ABS works
Old Oct 6, 2006 | 11:54 AM
maximagician's Avatar
its in the fsm brake section pg. br-14 in my 92 fsm
there is an adjustment bolt where the rear parrellel link connects to the
sensor spring
i think if the cars lower than the springs being pulled so loosen the bolt
a little and release the spring pressure and re tighten
there isnt really much adjustment room but i ll prob. do this if i ever
lower my 92
Old Oct 6, 2006 | 12:11 PM
Greeny's Avatar
¯\(°_o)/¯
I don't have abs...
Old Oct 6, 2006 | 12:20 PM
89blackse's Avatar
"and falling like a rock"
Originally Posted by MyGreenMax94
I don't have abs...
Then you dont have this load sensing valve.
Old Oct 6, 2006 | 12:43 PM
Greeny's Avatar
¯\(°_o)/¯
Oh....
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
