brake problem please help!!!!
Old Oct 13, 2006 | 12:34 PM
andos06's Avatar
i have a bad brake fluid leak coming from my car.it's coming from the round black cylinder looking thing that's just behind where you put the fluid into.is this the master cylinder ?? or is it just a resevoir for the fluid?? it seems to be coming out right at the front where the hose from the top up container attaches to it. can you fix the problem with a gasket?? any help would be great thanks.
Old Oct 13, 2006 | 01:53 PM
internetautomar's Avatar
mod or sell?
it's your master cylinder that is leaking INTO the brake booster (Black thingie)
REPLACE IT ASAP, otherwise you will destroy your brake booster.
Old Oct 13, 2006 | 02:55 PM
andos06's Avatar
it's coming out of the front where the screws are.
Old Oct 13, 2006 | 03:06 PM
Greeny's Avatar
¯\(°_o)/¯
Like internetautomart said...REPLACE IT! asap...Otherwise you will need a brake booster also..
Old Oct 13, 2006 | 04:07 PM
Mr. Blue Sky's Avatar
If you are going to switch master cylinders, you can check with autozone to see if you can buy a remanufactured(repaired) master cylinder. When I got mine for my 2nd gen it was a remanufactured OEM nissan master cylinder that I received(said nissan on the side, no sticker, looked original). 6 months later, no problems. Pretty sure it is the same with 3rd gens
Old Oct 13, 2006 | 04:10 PM
Greeny's Avatar
¯\(°_o)/¯
He lives in australia...
Old Oct 13, 2006 | 04:31 PM
andos06's Avatar
is it a hard job to replace?
is it a hard job to replace the brake cylinder? are there instructions on this site? cheers
Old Oct 13, 2006 | 04:42 PM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/showthread.php?t=396706
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
slowlifer
Sep 8, 2015 05:53 AM
