Timing belt gone?
Old Oct 16, 2006 | 09:11 PM
NineOhSE's Avatar
Timing belt gone?
For around a month now I'd been hearing a little noise from the passenger side of my engine. Well tonight on my way home, after making a stop I lost lost some power and I heard a LOUD clacking sound from the top left cylinder. I was wondering if when a timing belt goes is it all cylinders that get messed up? If not, what is the likely culprit here? I havent even had time to take off the spark plug to see if there any damage to it. So I guess thats where I'll being.
Thanks in advance
Old Oct 16, 2006 | 09:18 PM
Maxteca's Avatar
You lost some power, so the car still runs? If it still runs its not the t-belt. To check
pop off the top part of the t-belt cover. Good luck
Old Oct 16, 2006 | 09:27 PM
MAXIMUS G EKSUS's Avatar
If the timing belt broke, it is likely that you bent some valves which means new engine or rebuilt because VG are interference engines !
sorry dude but I hope it is not the case !
Old Oct 16, 2006 | 09:29 PM
Alex_V
sounds like it skipped some teeth and only one cylinder's valves are hitting the piston.
Take off the belt cover and take a look as well as at the plugs.
Whens the last time you changed the timing belt?
~Alex
Old Oct 16, 2006 | 09:59 PM
NineOhSE's Avatar
yea, the car still runs. I've turned it on and off a few times since it happened. The loud clacking seems to only be coming from one of the cylinders (Cylinder #1 I believe)
Old Oct 17, 2006 | 09:07 PM
vansskaterfreek's Avatar
maybe a rod came loose while it was idling and didnt create a hole in the oil pan..... maybe your belt slipped a tooth.....how many miles you got?
Old Oct 17, 2006 | 09:27 PM
NineOhSE's Avatar
201,xxx miles.... wouldnt any issue with the timing belt affect all the cylinders? The noise is only coming from the #1 cylinder...
Old Oct 17, 2006 | 10:03 PM
Jon94SE's Avatar
Definatly not a broken belt, I'd go with a skipped tooth as mentioned before. bummer.
Old Oct 18, 2006 | 06:35 AM
internetautomar's Avatar
mod or sell?
yes, and I would listen to see if the noise is up top or down.
up top, could be a collapsed lifter.
Old Oct 18, 2006 | 10:25 AM
NineOhSE's Avatar
It's definately up top! I probably wont be able to find out anything more until i get some time to try to fix it.... it could be a while.
Old Oct 18, 2006 | 06:38 PM
nForce's Avatar
The Computer Guy
Does it sound like this?
Click To View
http://video.tinypic.com/player.php?v=2ihwmsk
Old Oct 18, 2006 | 08:50 PM
NineOhSE's Avatar
Originally Posted by nForce
YEAH!! thats what it sounds like, but i could swear mine sounds like its coming from the top end. In the video it seems to be coming from the bottom end.
Old Oct 19, 2006 | 03:09 PM
nForce's Avatar
The Computer Guy
yea... same here. I had 5 shops look at that sound no one could figure it out. Then finally got it. It was the Timing Belt Tensioner Spring. I was drivin around with that stupid sound for about a yr till got my timing belt and stuff replaced. I had shop do it, but tell them to buy the Timing Belt Relpacement Kit. Its about 400 comes with everything including springs and waterpump and why ur at it put a Under Drive Pulley on it. I put one on mine makes big difference
Good Luck...
Old Oct 19, 2006 | 05:16 PM
NineOhSE's Avatar
Good Luck...
Did that affect the idle? because mine is idleing horribly but it sounds just like that
Old Oct 20, 2006 | 06:06 AM
nForce's Avatar
The Computer Guy
humm I dont really remember my idle being high. But then again this was about 2 years ago. So idk....?
Old Oct 20, 2006 | 07:56 AM
maxitech's Avatar
When replacing the T-belt, it is always a good idea to at least consider replacing the water pump, belt tensioner, cam seals, etc.
Old Oct 22, 2006 | 08:08 PM
phat's Avatar
Good Luck...
you got really lucky.
Old Oct 22, 2006 | 09:11 PM
rmdl51's Avatar
White_Shadow
damn! I being careless about timing belt, how often should be changed guys? I had my car for 2 years now and never take a look at it,
Old Oct 22, 2006 | 10:12 PM
Wolf-Strong's Avatar
50k miles seems to be a good average...Correct me if I am wrong please!
Old Oct 22, 2006 | 11:16 PM
Alex_V
The norm is 60K. Im in the middle of doing it on my 90se, it has 193K miles and it looks a little on the worn side, but still has good tension. Id say it was on a little too long.
~Alex
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
