Slight studder....
Slight studder....
I noticed now that when i go from a dead stop to accelerate there is a studder for about 300 rpms. from 700-1000 rpms and then its gone... its a 94 gxe (vg). spark plugs are all good. wires are good. dist good. new injecters. im kinda confused.
Check the engine foundation. It was three. One near the front of the engine and two under the engine, on either end of the crossbar. The rubber inside the foundation (or 'engine bush' as some call it) must have cracked. Replacing those will fix the shudder.
Originally Posted by heresmymind
how much to fix? shop? yourself? where can i locate the mounts on a vG?
inter - by the way i got the cv joint from you. fast shipping. thanks
I'm not sure if that is the case on yours.
you can do them yourself, but personally I'd let a shop do it in this weather.
RWCreative
Sep 21, 2015 11:01 AM
