power lock actuator pinout
Old Oct 24, 2006 | 02:51 PM
Sevorg1's Avatar
I have been having problems with my passenger side front door lock. It goes up, but not down. anyway I took out the actuator and would like to know if any one knows the pin out. there is a four pronged connector that plugs in the bottom. also red, black and blue wires that come out the side<------what are they for? I can hook it up to a 12v power source, but what should cause the actuator to go up and down. I'm pretty sure that the prongs on the bottom are all I need to make it go up and down. dont I need like a negative 12v pulse to make it go up and down? How should I test it?
Old Oct 24, 2006 | 04:59 PM
internetautomar's Avatar
mod or sell?
go buy the FSM and it will have the answers.
I'm just too lazy to look it up right now.
BTW chances are 2 of the wires are for the central locking system
Old Oct 25, 2006 | 03:59 AM
89blackse's Avatar
"and falling like a rock"
I have the exact same problem on my Gold max. I havent looked into it as there're is plenty more to go around on my maxima before i can think of fixing this.
If its setup like i think it is, it would use one polarity to go up and another to go down. But that is a guess.
Old Oct 25, 2006 | 05:29 AM
jackb_guppy's Avatar
Originally Posted by 89blackse
and falling like a rock.
Good Battlestar Galactia Quote!
Old Oct 26, 2006 | 11:18 AM
Sevorg1's Avatar
fixed. the actuator had a break in the internal circuit board. resodered the board, and grinded I alittle of the gear the causes the lock to go up and down off in order to clear the soder. and now it goes up and down. positive 12 goes up negative 12 goes down
Old Oct 26, 2006 | 01:14 PM
89blackse's Avatar
GREAT! Thank you. The .org pulls through again.
Did you happen to take any pics?
Old Oct 28, 2006 | 03:29 PM
Sevorg1's Avatar
yeah, I took pics, but I dont know where to upload them to, or how to post them
Old Oct 28, 2006 | 03:44 PM
Sevorg1's Avatar
][/URL]
the gear runs back and forth over the circuit board. where the needle is pointing is where the circuit was broken. the gear that goes back and forth has contacts on it so that when it is down and you press down on the lock button the motor will not go, so it doesnt burn up. and the same for when it is up and you press up.
pictures are out of focus, sorry
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
