heat!
Old Oct 30, 2006 | 12:31 PM
rafanthony's Avatar
heat!
how many of you dont have heat in your car like me?
Old Oct 30, 2006 | 12:33 PM
Greeny's Avatar
¯\(°_o)/¯
How many need to replace their thermostat like you?
Old Oct 30, 2006 | 12:37 PM
ICEMAN76's Avatar
That' hilarious
Old Oct 30, 2006 | 12:41 PM
rafanthony's Avatar
i put in the need t stat and it still does not work, unless I am driving fast and for a long time( hour plus) and then when i slow the the car starts to overheat
Old Oct 30, 2006 | 12:46 PM
89blackse's Avatar
"and falling like a rock"
Man i drove to work the other day, and my car never got to operating temp.
Old Oct 30, 2006 | 06:11 PM
DennisMik's Avatar
Its winter time and the annual "you need to bleed the air pocket out of the hight point of the engine" time is here.
Old Oct 30, 2006 | 06:42 PM
2Legal4Me's Avatar
it sounds like you guys are using stant t-stats there no good. Nissan's T-stats are better
Old Oct 30, 2006 | 07:33 PM
Greeny's Avatar
¯\(°_o)/¯
OEM is the way to go...
Old Oct 30, 2006 | 07:39 PM
Michael's Avatar
Back in a 3rd Gen.
yup and I was surprised to find out that the OEM one was cheaper (even from the local dealer) than the aftermarket ones.
Old Oct 30, 2006 | 07:44 PM
2Legal4Me's Avatar
over the years of owning my max i thought a few years back that the dealer sucks A#$. but as for most parts there relatively cheaper than autoparts stores
Old Oct 30, 2006 | 07:53 PM
rafanthony's Avatar
i have an oem
Old Oct 30, 2006 | 08:16 PM
Michael's Avatar
Back in a 3rd Gen.
Originally Posted by rafanthony
i have an oem
you need to get the air out of your system.
There is a bleeder valve on the motor...I know candiman did a little write up I read last week so the post should be on the first maybe second page...look for another heat related issue thread.
Old Oct 31, 2006 | 05:40 AM
rafanthony's Avatar
yeah , i know i have to lift the front of the car up and..... i remember them from last year. thanx
Old Oct 31, 2006 | 01:36 PM
Duckman540i's Avatar
VE Powah!!!
I searched every thread started by CandiMan, and nothing regarding a heat write up & so on. I also went back about 5 pages on the Forum, and couldn't find anything. Could you just post a picture of the bleeder vavle on a VE & maybe the procedure? Thanks Michael.
Old Oct 31, 2006 | 01:57 PM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/showthread....ht=air+pockets
Old Oct 31, 2006 | 02:31 PM
Michael's Avatar
Back in a 3rd Gen.
He didnt start the thread but I was wrong about it being in the last couple of days. I read it the other day so thats why I thought it was on this or the next page but I read it when I was searching for something else and the post was actually a while back...sorry bout that.
the bleeder screw is under the little tab that says "do not open when hot" or something like that. Its around the TB.
Here is the link to the thread
Old Oct 31, 2006 | 08:04 PM
92 Max's Avatar
The bleeder is a bolt on top of the bypass hose connection, right in front of the throttle body. It has a gold tag that says "Don't remove hot", or something to that effect, right next to it. You warm up the engine (not hot, like the tag says) and loosen the bolt and let the air escape until antifreeze dribbles out. However if you really have no heat, you need to do the jack the front up procedure in the writeup.
Old Oct 31, 2006 | 08:08 PM
92 Max's Avatar
Are you sure you got the thermostat in the right way? The spring goes towards the block and the pyramid shaped end goes towards the radiator. If it's backwards you can get overheating when the engine is slow and proper cooling when going fast ( stirs coolant enough to get it to the TS thermal actuator on the radiator (wrong) side).
Old Nov 1, 2006 | 07:33 AM
rafanthony's Avatar
i will check that out, my uncle put it in and he would do something like put it in backwards! I wont have time to check that for 2 weeks but i will let u know. thanx
Old Nov 1, 2006 | 10:27 AM
Michael's Avatar
Back in a 3rd Gen.
it will not go in backwards. I think I tried it just to see and it wouldnt fit but I may be wrong because its been a while...or course this is on the VE...I really cant remember on a VG because its been a really long time since I worked on one of those.
Old Nov 1, 2006 | 10:43 AM
Alex_V
It wont go in backwards on the VG either. I just put mine in 2 days ago. The "long" side of the tstat will point outwards on the VG.
~Alex
Old Nov 1, 2006 | 12:35 PM
MaximamixaM's Avatar
Not saying this is your problem, but my Maxima had a winter of no heat. The driver side vents had a tiny amount of heat, the passenger side had none. Turned out my radiator was low on coolant-noticed one winter night when the temp gauge went up toward the redline. Isn't there also some gizmo on the firewall that can fail and give you no heat? What about a clogged heater core in the dash?
Old Nov 1, 2006 | 02:27 PM
Jon94SE's Avatar
haha i laugh at you people with no heat! only joking, I've been lucky with this, my car is at operating temp within 5-10 minutes and it gets to be a bit of a sweat lounge in there after awhile. I'm dreading the day the ol' core goes out on me though. Untill then it's...
Old Nov 1, 2006 | 02:37 PM
505max94se's Avatar
Old Nov 2, 2006 | 10:34 PM
internetautomar's Avatar
mod or sell?
no heat is normally due to an airpocket
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
