broken bolt in the main pin
Old Nov 10, 2006 | 05:41 PM
zhusst's Avatar
Just spent the lovely afternoon on my maxima, changed both side ball joints, tie rod ends(Thanks internetautomart, I finally got the package today). Everything goes fine until it came to the brake pads, I broke the bolt on the MAIN PIN . Based on my current tool collection and experience, I perfer to just buy a new one somewhere. Any ideal where can I get one, is this sth most auto part store carries or I have to go to the dealership? Thanks for any suggestions from you guys.
Old Nov 10, 2006 | 06:09 PM
Greeny's Avatar
¯\(°_o)/¯
Try one of you're local junkyards...
Old Nov 10, 2006 | 06:18 PM
zhusst's Avatar
Thanks.
It is not that expensive(I guess) even from a dealer? Junk yard is too far from home and it is my only car
Old Nov 10, 2006 | 08:29 PM
Matt93SE's Avatar
STFU n00b!
So you just need to replace the pin and bolt, or is the pin stuck in the caliper as well?
If you just need the pin and bolt, it'll cost you about $12 at a local dealer. pin on nissanparts.cc is listed at 7.02 and the bolt is 3.66
I'd also recommend rebuilding the caliper while you have it off. the rebuild kit includes new rubber boots for the slider pin as well as the caliper seal and boot. it's $23.53 for the front axle set (both calipers).
Old Nov 11, 2006 | 10:43 AM
zhusst's Avatar
My dealer do not have them in stock, just got one from autozone, will try it on after lunch
Old Nov 11, 2006 | 04:27 PM
internetautomar's Avatar
mod or sell?
so did they have the right one?
Old Nov 11, 2006 | 04:58 PM
Greeny's Avatar
¯\(°_o)/¯
My guess will be no...
Old Nov 12, 2006 | 05:05 PM
zhusst's Avatar
It IS the right one, I took the old one to the store, they are the same.
The package came with 2pins and 2 bolts, I used one set. The other pin have a small rubber boot on, like this one:
Old Nov 12, 2006 | 11:48 PM
Duckman540i's Avatar
VE Powah!!!
Where do you get this rebuild kit? I don't have faith that Autozone/Checkers/Ect. will have the proper one for our cars.
Thanks.
Old Nov 13, 2006 | 06:57 AM
Matt93SE's Avatar
STFU n00b!
Stealership.
Old Nov 13, 2006 | 08:09 AM
ColombianMax's Avatar
Oh yea, thats a lot of fun! I had the same problem happen to me on my first break job on the Max except my guide pin was frozen in the caliper bracket. Make sure you lube them up real nice and be sure to stuff some extra grease inside the boot so that problem never happens again.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
