question
question
my sister has a 98 extera with a 3.3 liter v6 the same as the max or very simular. so my my question is does it have a timing chain or a belt.The dealer wanted to chang the timing belt because it has 90k miles on it. I have a 2k make and im 99% sure that it has a chain but i just wanted to make sure.
Yes. All VGs have the timing belt. The recommended interval to change it is every 60k miles I'm pretty sure. It's actually the first job I did on my Max, because my water pump had gone bad and leaked all over my original timing belt. I think they also recommend that you change the water pump, thermostat, tensioner, main seal and front cams seals while you're in there in order to save time and money (from having to go back in later). Good luck!
-Mrkanda
-Mrkanda
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
