CV Axle assembly
CV Axle assembly
Well, after 128,000K on my 94 GXE, the drivers side rubber boot on the CV slip apart, I guess from old age, I picked up a re-manufactured one from Advance Auto for $65.00 after core-return. I will be installing it this week, the passenger side one looks & feels in great shape, to I will let it stay for now, a competent mechanic told me that it should not take longer than 1/2 hour if you know what your doing, anyone out there have replaced this part before?
Well i hate to break the news to ya,but on automatics,the passenger side axle must be removed first before the driver side,then you need a long screwdriver or other suitable tool to knock the d-side shaft out from the passenger side hole..
The rest of the info for removal of the cv shaft is in the repair sticky..
http://www1.autozone.com/servlet/UiB...rGuideYMMEYear
SIDE NOTE: Don't forget to drain the tranny fluid into a suitable container before you start the shaft removal...
also make sure you have a socket big enough for the nut at the end of the axle.
Originally Posted by DanNY
i'm going have to disagree here. you CAN pull just the DS axle out w/o pulling PS axle out. get a pry bar and pull it out of the tranny.
I was going by that anyhoo,i haven't had take one out of the wifey's car yet
Edit: I thought you were jeff..
Go check yur idiotzone sticky..
well autozone uses the FSM as their guide. i'm using hands on experience as the guide.
Yeah,hands on is always better info imo,Good thing this thread came along though,i would have taken both sides out...
Thanks for the input, but after looking at the sticky from Autozone, I think that I will have my mechanic install this CV assembly, looks way to time consuming since I have never done one before. Question: How long can you drive on with a broken rubber seal on the CV joint?
I agree on the axle removal...no need to remove passenger to remove driver side. Dude if you got time and want to learn I'd suggest to do it yourself, plus it'd be cheaper and you get to bond with your vehicle
Oh be sure to to inspect the axle seal (ugh) if it doesnt seem all torn or bent just leave it alone.
All tools you'd need would be:
Jack/jackstands
14mm
17mm x2
19mm
36mm (axle nut)
nice prybar (set preferable)
Pliers to pull cotter pin
Torch (optional)
Thats all I can think of tool-wise but that should pretty much cover what you'll need.
Oh be sure to to inspect the axle seal (ugh) if it doesnt seem all torn or bent just leave it alone.All tools you'd need would be:
Jack/jackstands
14mm
17mm x2
19mm
36mm (axle nut)
Torch (optional)
Thanks for the advice.......my fellow brothers of the Maxima Community are AWESOME!!!
i think you should grab a beer and have at it because you'll never do it a second time until you do it the first time
anyway to knock the pass side out im taking the tranny out already got the drivers side axle off.. or should I just slide th tranny to the driver side and get it out that way? theres only a inch or 2 of clearence though
there's 3 10mm bolts on it..then take a nice big hammer and spin the bearing side to work it out. total PITA.
After reading these threads, I have come to the conclusion that God put ASE certified Mechanics on the beautiful planet earth just for these types of problems........that we non- ASE certified humanoids may encounter!!!
Originally Posted by ColombianMax
Lotta shops claim to be ASE but its just experienced mechanics. Is that scary enough to get you to DIY?
separate the pass side axle from the bearing carrier. once it's loose from THAT then the axle will slide out also.
got the car up about a foot or so.. im just creepin under the ***** until i raise it a foot/half for the tranny install
My Mechanic is awesome, ASE certified, used to work for Toyota, know he works for himself in his own shop, he will Keep my 94 GXE on the road for many more years to come.....he told me that the Max will run as long as I want it to....& then some!!!!
I have driven for thousands of miles with broken boots without problems,but eventually,water/dirt will destroy the cv joint and it will start to clunk around corners...
mine makes a clicking noise from the passenger's wheel area when i make left turns or most turns. Could i have a broken boot also?
Originally Posted by khemraj1999
not to hijack the post but..do u mean make a clicking noise when u make turns?
Yeah,sounds like you're passenger side cv joint is broken..
would it harm anything if i continue driving it for a while until i get money to fix it.
I wouldn't do any honda civic challenges at the stoplight until it is fixed though..
I should be fine for a while,it takes quite a while before a nissan cv joint completely fail...
..but thats a totally drifferent post eh.Thanks all!
U Guys are the BEST BEST BEST !!!
Your help is really appreciated.
Khemraj.
James92SE
142
Jan 2, 2024 09:23 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
atriuum
Sep 28, 2015 01:19 PM
