Engine Whine VG
Old Nov 30, 2006 | 02:29 PM
Maxima Man's Avatar
Engine Whine VG
My 89 max has made this superchager/turbo whine for a long time when accelerating and I was wondering what could be the cause of it.
I know most people would want to keep it but I want to make sure nothings going wrong.....
Any ideas what it is
Old Nov 30, 2006 | 02:56 PM
maxmaxima91's Avatar
i know when my timing belt was to tight it sounded just like a superchagers... could be that..
Old Nov 30, 2006 | 03:00 PM
Maxima Man's Avatar
I just recently had the timming belt replaced but it whined im pretty sure before I had the belt replaced so I don't know if it was from that or not.
Old Nov 30, 2006 | 03:21 PM
goon9's Avatar
Power steering sometimes whines when needs oil.
A bad ground in a stereo ESSPETIAlly bose will whine.
A dieing auto tranny while whine.
These things can make you think the engine is whining if you not sure what they sound like.
Check your belts.
Old Nov 30, 2006 | 03:32 PM
Maxima Man's Avatar
Power steering has plenty of fluid new PS hose .
No more bose in my max all pioneer .
The whine winds up with the rpms so I think it may be pointing to the transmission. NOOOOOOOOO BAAADDD......
I hope its not the trans I can't recall if it whines while reved up in park.
I hope it does then I could rule out the trans.
What makes a old trans whine .........?
Old Nov 30, 2006 | 04:57 PM
Hectic's Avatar
my ve sounds like it's got a little turbo on it sometimes "fwwwwwip". probably an intake leak or something, i dunno it sounds cool though
Old Nov 30, 2006 | 05:50 PM
Maxima Man's Avatar
This sounds like a whine suddle to most but I notice it and I just don't want any noise to go unattended to.
One time I put some Prestone Belt dressing on my belts and it helped if not completly removing the sound for some time (not long) But it was a while ago and I cant recall if it got rid of the sound completly or not.
If it is a belt noise the belt is too tight right because if a belt is loose it will squell (sp) right?.....
I didn't put the belts on last it was the nissan mechanic who replaced the belts and water pump so I don't know how tight he put them on.
How much should the belt move when pressed on for a given distance between pulleys?
Sorry for all the Q's
Old Dec 1, 2006 | 02:05 PM
Maxima Man's Avatar
anyone home?
Old Dec 1, 2006 | 03:57 PM
akurtzer57's Avatar
i put my car in neutral coming to a stop and my tranny just went out. sorry have to post 15 replys before i can start new threads'
Old Dec 1, 2006 | 04:14 PM
Maxima Man's Avatar
WOW I sometimes put my car in neutral when stoping fast so my trans dosen't have to down shift too fast.
I wont do that anymore
I don't want my trans to leave the max and I don't have 2,000 for a rebuild or a used trans.
Can anyone tell me........if a belt that is too tight will whine or not?
Old Dec 2, 2006 | 05:29 AM
maxitech's Avatar
It can...use your better judgement to adjust it tho. Find a good midpoint between the belt having too much play and it being tight to the point where there is no play.
Old Dec 11, 2006 | 07:23 AM
mikekanterakis's Avatar
I recently changed the timing belt on my '92 maxima. I tried to apply the 25lbs of pressure on the belt between the two gears for the cams, but when I had it all back together, it started making that smooth super-charger "type" wine. Belt was way too tight and it was causing the cam towards the front of the motor to rub hard on the cam bearing. Very Not Good! I loosened it up a bit and now it's just fine.
It's definitely a BAD noise, and I recomment not driving your car if it's making that noise. It'll sound cool until you wear through the bearing. Then it's all bad news from there.
Old Dec 11, 2006 | 12:42 PM
PMONT's Avatar
i have a 5 speed thats makes that noise i was told it is caused by a spring that controls the valves going bad, not the valve springs but the one that involves timing
Old Dec 11, 2006 | 02:28 PM
maxitech's Avatar
...what???
now I get it!
Old Dec 11, 2006 | 02:34 PM
Pearl93VE's Avatar
I can has?
edit: Ohhh, wait. VTC Clacking?? VERY common on VE30DE's...
________
Mary Jane
Old Dec 11, 2006 | 02:47 PM
elusivemax93's Avatar
a tranny rebuild costs around 1600 shouldnt cost u 2 grand to be done thats in my own opinion over charging u by 400 dollars
Old Dec 12, 2006 | 01:14 PM
Maxima Man's Avatar
A Nissan tech. replaced the timing belt I hope they didn't tighten the belt to much. Did you hear inside the cabin the belt whining at idle or only while accelerating?
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
