3rd gen repair issues.
Old Dec 2, 2006 | 09:33 AM
rowanapps's Avatar
Hey fellow maxi owners, i have 3 questions i need answered...
1 my muffler is rusted out badly, does this effect fuel consumption,
performance etc?
2 im finding my coolant is dissapearing from my radiator although there is no leak that I can see, what could it be?
3. sometimes my motor wont start in park, only in neutral why is that?
Thanks alot for your comments.
Rowan
Old Dec 2, 2006 | 09:39 AM
xx-Marshall-xx's Avatar
kthxbye2u
i cant really answer your questions but you have used the EDIT function before right?... you dont have to post 2 times if you mess up on the first one
well number 2, if its disappering i suggest look harder for coolant leaks... i found 2 on mine one time after i fixed 1 i saw another :-/
Old Dec 2, 2006 | 10:00 AM
Greeny's Avatar
¯\(°_o)/¯
performance etc?
Rowan
1.The muffler rusted out would not effect gas mileage too bad,if at all..
2.Check for leaks at the water pump and all hose connections carefully..When the waterpump leaks the coolant tends to drip off the front of the oil pan by the crank pully..
3.A bad shifter bushing is most likely causing the no start in park issue...
Old Dec 2, 2006 | 02:19 PM
mikekantor's Avatar
3) This happens to me sometimes, it helps to toggle the shifter forward a few times.
Old Dec 2, 2006 | 06:26 PM
jackb_guppy's Avatar
2) Also check thermstat. Just had a problem with thermstat not opening, caused back pressure pushing collant into reservoir and the overflowing while driving. When stop the system cools and sucks all the collant left over back in, but at lower level.
3) Bushings. I use to just hit shift in Park to "more Park" and all was well. I have since replaced all bushings.
Old Dec 4, 2006 | 06:33 PM
rich in co's Avatar
MGM94 hit it start at the pump and start tracing and you should find the leak.
Old Dec 5, 2006 | 01:17 PM
92slacky's Avatar
Radiator cap/gasket could be compromised.
Old Dec 7, 2006 | 12:45 PM
mr.writes253's Avatar
I need help too since maxima.org won't let me post a thread yet.
I have 93 Maxima and I have a few questions about some issues with my car. I'm fairly handy when it comes to repairs, but I still consider myself a novice.
1) I just replaced the front brakes myself a couple od days ago and I had to bleed the breaks cause I didn't have a c-clamp to depress the caliper. Well, my breaks are fine, its just when I press the brakes now in park I get a click sound from the shifter area. Ideas??
2) How do I know if I need new struts?
3) My air control unit only works on the 4 level. I heard that some regulator had to be replaced- but I'm not that sure.
Old Dec 7, 2006 | 12:46 PM
Also,
I get a clicking sound when my car starts up, but goes away. Is this normal?
Old Dec 7, 2006 | 02:13 PM
Greeny's Avatar
¯\(°_o)/¯
1. The click you are hearing is the safety shift lockout selonoid, it's purpose is to prevent you from putting the car in a gear without first depressing the brake pedal,this is normal..
2. Push the front end down a few times hard,if it keeps bouncing after you stop pushing on it,you probably need new struts.
3. You need to replace the blower motor resistor,located under the dash on the passenger side attached to ac/heater housing..
Old Dec 7, 2006 | 02:22 PM
nForce's Avatar
The Computer Guy
I have same shifter and coolant problem with mine. I just push the shifter up before I start it an My coolant tents to just fill up and overflow out of the overflow tank alot..
Old Dec 7, 2006 | 05:37 PM
Yo Mr.MyGreenMax,
Thanks for the help!
captchaos
Mar 15, 2016 12:18 PM
97_GXE
20
Sep 17, 2015 08:12 PM
dcam0326
Sep 8, 2015 11:02 PM
