Removing Transmission
Old Dec 3, 2006 | 12:21 AM
Gun5's Avatar
today i got the tranny dropped on the jack but the passenger side driveshaft is the only thing catching keeping the transmission in the car at this point I was told it should just slide out, obiviously its not any tips? I got 8 days to get this thing finished
thanks ryan
edited dec 10
Old Dec 3, 2006 | 01:31 AM
Greeny's Avatar
¯\(°_o)/¯
Support the engine with the cherry picker and drop it out the bottom...
Old Dec 3, 2006 | 06:09 AM
Matt93SE's Avatar
STFU n00b!
remove the y pipe to get easier access to the carrier bearing bolts. but a pivoting head 1/4" ratchet or breaker bar will do the trick. the investment in my Snap-On TH737 ratchet was WELL worth it for getting to those stubborn guys.
http://buy1.snapon.com/catalog/item....re&dir=catalog
As for engine mounts and stuff, once you remove the two body mounts on the driver's side, you can leave the engine itself alone. the two large engine mounts will support the engine- albeit it will lean to the side a few degrees. nothing enough to cause any damage. support the tranny and unbolt the two mounts attached to it.
then pull out all the bellhousing bolts and separate.
In fact, you don't even have to remove the pass side axle. you can remove the tranny without pulling it. makes it a bit easier to reinstall the tranny as well since it gives you something to aim for with the back of the transmission.
Old Dec 5, 2006 | 10:50 PM
Gun5's Avatar
we loosened up all the bolts today and flushed the lines we CANNOT get the 2 bolts on the rear tranny mount lose we rounded 1 side of the inner nut off alittle bit so we just stopped how do we get the damn thing off cant take the mount off because when the tranny goes down it will hit the frame
Old Dec 6, 2006 | 01:26 AM
Wolf-Strong's Avatar
If you stripped a bolt, I find Vice Grips to always be handy!
I was concidering doing a 5 speed swap sometime in my life, so thanks for making this thread! Will help me conciously prepare!
Old Dec 6, 2006 | 07:27 AM
Matt93SE's Avatar
STFU n00b!
Exactly which bolts on the mount? there are 6 on the rear tranny mount. you can take it apart a couple of different ways, so you may be able to finagle the thing out by dissassembling the rest of the mount and provide enough clearance to drop the tranny and then remove the stripped ones.
also.. 6 point sockets and wrenches are your friend now. don't even think about using an open end wrench or a 12pt socket.. the $10 to go buy a 6pt wrench or $5 to buy a socket will be well worth it.
Old Dec 6, 2006 | 01:49 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah,never use anything other than a 6 point socket to break bolts loose,also it might help to spray some liquid wrench/pb blaster on the threads of the mount bolts to help loosen the rust..If you do decide to get some 6 point sockets,i suggest getting a higher quality brand of socket like craftsman or cobalt,or even better get snap on..I have noticed of the years that cheap sockets tend to strip bolts just as bad as a using the wrong socket[i.e 12 point] Probably due to low quality metals used in a cheap socket...
Old Dec 6, 2006 | 08:36 PM
Hectic's Avatar
tissue over the socket will help to get a grab on those stripped bolts.
Old Dec 9, 2006 | 09:20 PM
Gun5's Avatar
thanks ryan
Old Dec 9, 2006 | 10:26 PM
Gun5's Avatar
bump
Old Dec 9, 2006 | 10:45 PM
elusivemax93's Avatar
bro its not gonna juz pop right out like a peice of cake ur gonna have to either pry it or tug on it real hard to get the passanger side drive shaft out and also it would be alot better if u removed the passanger side drive shaft to get the tranny to come out and go up much easier ive done both auto and manuel tranny drops the passanger side drive shaft has three bolts holding the pasanger side drive shaft in its place the three bolts are not easy to reach and you will have fun
Old Dec 10, 2006 | 01:04 PM
Gun5's Avatar
got the 3 bolts out today with 3 different size ratchets (had to go buy a 3 inch mini one to) now where do i start prying ? or hitting it
Old Dec 10, 2006 | 02:17 PM
Hectic's Avatar
save yourself a lot of time and skip removal of the right axle. just pry and pull the tranny away from it, make 100% sure you've removed all the bolts because there's a couple that are tough to see. if all engine/tranny bolts are removed a little prying will separate it pretty easially. for reinstallation be careful and slide it straight onto the axle again. it's a hell of a lot easier and faster than dealing with removal of the axle, plus the input shaft will act as a guide.
Old Dec 10, 2006 | 03:40 PM
Gun5's Avatar
so just start prying again? aight... ya all the bolts are out the damn thing swings all over the place when i bring the tranny jack down... just pry the tranny from the engine correct? what about when the tranny hits the frame?
Old Dec 10, 2006 | 04:05 PM
Greeny's Avatar
¯\(°_o)/¯
Just take the passenger side shaft out and be done with it..
Old Dec 11, 2006 | 06:03 PM
Gun5's Avatar
dropped... .. final cleaning on the junkyard one, new filter/gaskets/ clutches and band tomorrow.. still have no idea how to put that damn thing on??? i wanna get this thing done
Old Dec 11, 2006 | 07:37 PM
is urs an auto tranny or manuel tranny bro
Old Dec 11, 2006 | 09:39 PM
Gun5's Avatar
auto
Gun5's Avatar
auto
Old Dec 11, 2006 | 09:42 PM
o damn did u remove all the bolts on the inside of the tranny and motor mounting area that holds the torque converter to the flywheel?
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Socalstillen
Sep 20, 2015 11:46 PM
