Fuel Injectors?
Old Dec 6, 2006 | 05:35 PM
Wolf-Strong's Avatar
Fuel Injectors?
I was trying to do some window shopping on google to find out what place might be the cheapest to get a full set of injectors from and saw this site:
http://www.fiveomotorsport.com/Injector_SetsNISSAN.asp
6/Set: $339.50
Plus $90 Refundable
Core Charge
Seams REALLY cheap; almost half of anyone else. My thoughts are that they are most definatly remanufactored, but hell if they work for another 150k miles, then awsome for that price. So any thoughts? Opinions?
Old Dec 6, 2006 | 05:43 PM
Greeny's Avatar
¯\(°_o)/¯
Waste of money if they are remans....
Used injectors would be preferable to remans imo...
Old Dec 6, 2006 | 06:04 PM
Any reasoning behind that?
Old Dec 6, 2006 | 06:28 PM
Greeny's Avatar
¯\(°_o)/¯
Remans have a high failure rate....
Old Dec 6, 2006 | 06:39 PM
No bueno!
Guess I'll just have to save up to buy new then
Old Dec 6, 2006 | 06:50 PM
Greeny's Avatar
¯\(°_o)/¯
No bueno!
Yeah,if you plan on keeping the car,then i would not put in any less than new..
Old Dec 6, 2006 | 08:23 PM
Hectic's Avatar
they're remanufactured, 3 year warranty though. http://cgi.ebay.com/ebaymotors/Nissa...ayphotohosting
Old Dec 6, 2006 | 09:26 PM
Awsome thanks. Yeah a 3 year warrenty with it would be PERFECT! I plan to rebuild the engine in a year or two (for the experience) and make it into a show car. Well that might be the way to go then....now to just get the $300 lol!
Old Dec 6, 2006 | 10:22 PM
Hectic's Avatar
you might want to check if it's a full warranty though. from how it reads it seems like maybe if the coils go, you won't be covered.
Old Dec 6, 2006 | 11:04 PM
Yeah something I will have to look into when I actually have money for em.
Old Dec 7, 2006 | 07:47 PM
internetautomar's Avatar
mod or sell?
Ok, I will repeat what I said in another thread.
I have spoken to multiple rebuilders that are reputable and they all say that they are lucky if 5% of all maxima injector cores are rebuildable. of those that are rebuilt and met spec, they fail about 1/2 the time.
Those are #s from GOOD rebuilders. the cheapo rebuilders that you typically find on ebay problem have a higher defect rate.
Because of remans I replaced 7 injectors on my first VE
Old Dec 7, 2006 | 10:13 PM
Damn you and convincing me to make the choice of going with new ones..
Old Dec 7, 2006 | 10:31 PM
Alex_V
And even if the ones with the 3yr warranty have a all inclusive warranty, how many times would you feel like ripping out 1-6 injectors to send in to get replaced? Yea didn't think so. Buy new, then theres no worries.
~Alex
Old Dec 8, 2006 | 05:05 AM
I30tMikeD's Avatar
If you need a set of stock rebuilt injectors give us a call
www.deatschwerks.com
405 415 6862
Old Dec 8, 2006 | 05:07 AM
I30tMikeD's Avatar
What are these "rebuilders" replacing on the injectors? Are they trying to replace the coil?
Old Dec 9, 2006 | 02:06 AM
bvtran's Avatar
94c Big Max
save your money and do what I did:
http://web.syr.edu/~bvtran/injectors.pdf
I paid $60 at http://www.witchhunter.com/ to have it clean up. They're the same process those remanufacturers used. Just be sure your injectors resistance are ok before you proceed. Otherwise, head to the junkyard and pick some up and sent in for rebuilt.
6/Set: $339.50
Plus $90 Refundable
Core Charge
Old Dec 10, 2006 | 01:13 AM
DaWifey's90's Avatar
what can my max do for me
i'm torn between going OEM or bosch aftermarket.
OEM's have lasted me over 200K miles, but the bosch are cheaper and have a longer warranty...
arguements for either one from anyone else?
Old Dec 10, 2006 | 07:11 AM
mod or sell?
arguments for either one from anyone else?
No argument, Bosch = OE on the injectors. they are exactly the same part.
Old Dec 11, 2006 | 01:08 AM
really?! how come they come with different warranties? it almost seems like it depends who you purchase them from rather than the fact that you're buying the same product.
Old Dec 11, 2006 | 08:31 AM
Badman_Maxima's Avatar
Hey, Personally I'd recommend the OEM injectors, in the case of what i went through, alot of aftermarket injectors seem to fail more quicker then the original oem injectors.
If you are looking at using your original injectors, have them cleaned and ohm tested to make sure they are working fine. Injectors after a long time need to be maintained and cleaned.
In most cases your OEM injectors are just fine
Old Dec 11, 2006 | 06:04 PM
mod or sell?
it does depend on who you buy them from for the warranty.
but the part in the box is the same.
In most cases your OEM injectors are just fine :read:
Cleaning them is what kills them, Nissan released a TSB recommending against cleaners in the tank, which are much less caustic than the ones used when rebuilding them.
there is no new aftermarket injector for 93 and newer maximas. they are all bosch/OE rebox
Old Dec 11, 2006 | 10:12 PM
so i may have killed my own injectors with seafoam?
Old Dec 12, 2006 | 12:38 PM
ive used CVU and delphi both and didnt last long, went back to OEM's which stayed real consistant. Havent had problems cleaning them ...yet! haha!
Old Dec 12, 2006 | 05:16 PM
mod or sell?
Seafoam isn't a solvent per say so it really doesn't do any damage
Old Dec 12, 2006 | 11:32 PM
really?....maybe i should take this to the fluids and lubricants forum...
by "per say" did you mean "per se"?
Old Dec 13, 2006 | 03:15 AM
mod or sell?
Probably the second one.
I wasn't an English major
Old Dec 14, 2006 | 01:19 AM
hehe...neither was I...but i do speak the language...it's latin btw, not english...
heh..it's one of those useless pieces of information that was embedded in me in high school....and now i can't help myself...
Old Dec 15, 2006 | 04:49 AM
I30tMikeD's Avatar
If you have a failing OEM injectors, the route to go is reman OEM's. Not aftermarket. The term "Reman" may not be the most accurate, since no injector company replaces the coil. But extensive testing can be done to ensure the coil is in good working order, flow rates are balanced, and spray pattern is acceptable, filters, spacer, and o-rings are replaced.
The thing about mixing and matching OEM's and aftermarkets is that most likely you will have two different performing injectors. Coil response could be slightly different, spray pattern could be different, and even flow rates can vary.
Do a simple ohm check before replacing/servicing injectors. (clean connectors of corrosion first). If they are not between 11-13 ohm's the injector is most likely bad. Don't waste your time on a injector with bad ohm's. Send the rest to a place who does off the car injector service and who can provide replacements if needed. More extensive coil testing can be done to evaluate if the coil is still in good working order. After cleaning, sonication, flushing, and flow testing a determination can be made of which need to be replaced and which are in still good working condtion....then go from there.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
