Is this normal in the cold?
Old Dec 31, 2006 | 05:56 AM
ColombianMax's Avatar
Hey guys, I'm a little concerned and wondering if my car is supposed to sound like this when I turn it on..it only makes this sound for like 5 seconds after I start the car and I noticed it only in the cold.. here's a video.
Sorry I kind cussed in the video, just a heads up if there's children
http://s24.photobucket.com/albums/c4...t=MOV00278.flv
btw the suction noise in the video isnt a vacuum leak, its cuz I accidentally put my finger over the mic on the camera
Old Dec 31, 2006 | 09:34 AM
internetautomar's Avatar
mod or sell?
my vote is exhaust leak.
Old Dec 31, 2006 | 10:54 AM
heresmymind
GXE means get lifters adujusted and an oil change. mine ticks the same way abotu 2 weeks before its time to change oil, granted I have a slight oil leak. get lifters adjusted too. makes your engine perrrrrrrrrrrrr
Old Dec 31, 2006 | 12:16 PM
nForce's Avatar
The Computer Guy
ha mine use to make that same sound till I started doin oil changes at 2500 to 2800 miles inted of like 3000 or 3500. So idk? Wat kinda oil do u use? I always get GTX High Miles or QuakerState High Miles and always 5w 30 weight.
Old Dec 31, 2006 | 02:42 PM
I do my oil change every 2000-2700 miles and its not time to do it yet.
I use Castrol GTX 10w 30 summer and 5w 30 winter but ever since this sound I'm thinking of going 10w40 summer and 10w30 winter but then again I dont know if its something inside engine or exhaust leak as brian said..
I just got my studs done..wtf?
Old Dec 31, 2006 | 03:38 PM
Greeny's Avatar
¯\(°_o)/¯
I'm going to call lifters...
Potty mouth..
Old Dec 31, 2006 | 08:56 PM
2k3TitaniumSe's Avatar
hmm sounds like lifters. same sound from my friends car until they were adjusted.
Old Jan 1, 2007 | 12:05 AM
only when you start it in the cold though? how hard is it to adjust these so called "lifters"?
Old Jan 3, 2007 | 04:19 AM
Gen3BluMax's Avatar
My car does the same thing. It only started happening after i put 20w50 in (in Aus its a fair bit hotter so this is generally ok to use) i have just bought some 15w40 synthetic oil and will see if it does it then. Another user on maxima.org.nz had the same problem using such thick oil and when he changed to a lower weight the noise went away.
Old Jan 3, 2007 | 06:40 AM
Scope's Avatar
Im izz sexay
Definately time for a oil change and filter replacement. Use a lower weight as stated above to see if that works.
Old Jan 3, 2007 | 07:30 AM
rimaximaman's Avatar
Believe it or not when I ran 10w-30 upon startup from a cold start I used to hear the lifters for several seconds until the oil got up to that part of the engine, since I only run 5w-30 now, I don't hear that anymore at all.
Old Jan 3, 2007 | 03:57 PM
Its only been 1500 miles since I changed my oil and filter so its definately NOT time for that
Hopefully its not time to pull the heads either. If it was a lifter wouldn't it make that sound all the time instead of just 4-5 seconds after a cold start?
Old Jan 3, 2007 | 04:08 PM
94 max's Avatar
problem is I'm sure with all the miles on car oil pump is worn and oil passages not as clean as it's taking a few more secs to get oil up top..last thing to do is rev it on start up...going to a synthedic oil will allow for faster flow on start ups...quaker state wouldn't even be a choice...try some mobil 1 10w 30
and a amsoil oil filter or a K.N part #hp2008 both work good....amsoil is by far one of the best oil filters on the market..hastings make the filter for them
Old Jan 3, 2007 | 06:23 PM
slickblack94's Avatar
put a peach can on it.
Old Jan 3, 2007 | 06:39 PM
Greeny's Avatar
¯\(°_o)/¯
I use fruit cocktail on my vg..
Old Jan 3, 2007 | 06:43 PM
heresmymind
hmm fruit cocktail on a dirty *** engine, hmmm nothing more appetizing. :-p
Old Jan 3, 2007 | 06:50 PM
Greeny's Avatar
¯\(°_o)/¯
I can eat off my VE/VG..
Old Jan 3, 2007 | 09:10 PM
Alex_V
John its lifter tick, no worries.
Theres a cylinder shaped thing between the valve and rocker arm that comes off the cam (the rocker arm is actuated by the cam and pushes down on the lifter). The VG's lifters are hydraulic which means they are self adjusting.
What happens is they get dirty and collapse when theres no oil in them and some times it takes a while for them to build up pressure like when your car is cold and has been sitting.
Id poor 1/3 to 1/2 a can of Marvel mystery oil in there, and 150miles before the oil change add half a can of seafoam. It'll really help after you change the oil. I do that every time I change mine and it helps my KA run alot longer.
~Alex
Old Jan 4, 2007 | 03:03 AM
Well do you guys think my engine is doing this cuz of driving on "2" instead of "D" when my tranny was bad? Yes I was constantly on 4-5k RPMs, I drove with messed up tranny for nearly 1 to 2 months before I replaced it
Old Jan 4, 2007 | 09:31 AM
Alex_V
Age/dirt. The high rpm driving may have just made it show up but I wouldn't be worried about it. Do the MMO/seafoam treatment and it'll be good after you change the oil.
~Alex
Old Jan 4, 2007 | 01:11 PM
I think its lifter knock. I also put 1 quart of resilon
in at every oil change. If that dont work put 1 Q of
resin in it. That will fix anything
Old Jan 14, 2007 | 06:41 PM
brynm's Avatar
IT'sounnds like lifters, my 88 SE-V6 truck makes the same noise, just takes a couple seconds for the oil to work it's way back up
Old Jan 14, 2007 | 09:52 PM
paesantom's Avatar
my exhaust studs are broken and that doesnt sound like that... i dunno what that is
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
TKHanson
Nov 24, 2018 01:39 AM
