Oil Issue
Old Jan 12, 2007 | 11:05 AM
heresmymind
Oil Issue
I have a leak. and after about 2500 miles the oil light pops on. i'm gonna just add oil for now. not sure what oil to add. or what was in it before. it has 150k miles and a SLIGHT lifter tick. any recomendations?
Old Jan 12, 2007 | 11:34 AM
Maximahappy22's Avatar
when i got my timing belt replaced the other day my mechanic said my right cam seal was busted and was leaking oil, it might be that....
Old Jan 12, 2007 | 11:52 AM
DanNY's Avatar
Ad·min·is·tra·tor
where is it leaking?
heresmymind
it doesnt leak anymore. i had to replace the head gasket. while doing that it sealed the rocker covors and stopped leaking. i asked my mechanic he said he put in 10-30
Old Jan 12, 2007 | 12:06 PM
Greeny's Avatar
¯\(°_o)/¯
Put a piece of cardboard under the engine overnight,then look around with a good flashlight above where the puddle of oil is at on the cardboard...
Some oil leaks travel across other parts of the engine from their origination point,so look carefully at the area of the drip point..
Old Jan 12, 2007 | 12:29 PM
Cliff Clavin's Avatar
Way out West
OK, which is it?
Do you have a leak or don't you?
Old Jan 12, 2007 | 12:43 PM
thatforrestkid's Avatar
i had a bad cam seal which oiled up my timing belt nice and proper. if you suspect a cam seal and have a belt, get it checked out. if it was leakin on your belt tho and was bad he would have said somethin i figure
Old Jan 12, 2007 | 12:52 PM
heresmymind
it used to leak. i just replaced the head gasket this week. myself. with a full gasket kit. and was able to clean the throttle body intake plenum and other things. had timing done so forth. was wondering what oil i should use. sorry i made it sound wrong in the first post ><
Old Jan 12, 2007 | 01:24 PM
bvtran's Avatar
94c Big Max
I had light leaks around the crank area too. Never enough that I saw leak drops on the grounds. My tranny does it too. Never drop any oil onto the ground. So it never brothered me.
Old Jan 12, 2007 | 07:14 PM
Way out West
look in the owner's manual and see what it says.
Sometimes it depends on the weather and where you live. I think 10w30 or 5w30 are generally preferred.
There is an oil and lubricants section to see all the arguments about which brand to use.
Personally, I use Mobil 1 because it's cheap at Costco. When I can't get to Costco, sometimes I use the NAPA brand synthetic oil. The manager there told me it was Valvoline.
Old Jan 14, 2007 | 02:27 PM
VEvolution's Avatar
I miss my VE
If you let it get to the point of where the oil light comes on, maybe thats a bit risky, no?
Mar 12, 2020 12:06 AM
kjlouis
Oct 3, 2015 05:29 AM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
ag90fox
Sep 9, 2015 12:22 PM
