replacing bumper
Old Jan 17, 2007 | 04:44 PM
Trevmister1610's Avatar
replacing bumper
so i og t anew bumer and started to take the old on off, but i ran into a problem!! how the heck do u get the headlights out to be able to get to those few screws under them?
thanks
ps all links and stuff with pics are very good!!
Old Jan 17, 2007 | 05:20 PM
bvtran's Avatar
94c Big Max
let's pick right hand side for example
it's pretty easy, there are 2 nuts (around 10mm) on the left side and 2 bolts (around 10mm) on the side. To get the 2 bolts out, you need to remove your side headlight out, there is only one screw that is holding it down. Pretty easy once you get the side headlight outta way.
Old Jan 17, 2007 | 05:22 PM
bvtran's Avatar
94c Big Max
also, don't forget you gotta remove the whole headlight housing along with the back mounting bracket... the one that attaching to your grill.
speaking of the grill, it's a pain to take off for me. I took it off by removing both headlight. If any of you guys could figure out a way to get a plier in there and get that plastic thing loose so the grill comes out let me know.
Old Jan 17, 2007 | 08:04 PM
Chris Gregg's Avatar
Get Off My Lawn
There are several different grilles, but the one I had, you could access what looks like a phillips screw. You take a phillips screwdriver and turn the plastic clip sideways and you are able to release the grille at that point. Move to next. I agree, grilles are a pain!
Old Jan 18, 2007 | 07:09 PM
bvtran's Avatar
94c Big Max
mines are held back by push clips. It's really hard for me to get a plier in there to push it out without breaking it. Yes, I already broken one of the 4 corners because Nissan had a 3rd non-removal metal clip that gets in the way. I'll just remove both headlights next time I do it.
Old Jan 18, 2007 | 07:11 PM
bvtran's Avatar
94c Big Max
yeah I need a new grill, I know a lot of you guys had converted to UK so you don't need your old one. If your old one was in decent condition, sell it to me.
vingodine
45
May 21, 2016 12:46 PM
JoshG
21
Sep 4, 2015 09:04 PM
maxipower
Aug 21, 2015 11:10 AM
Samedi
Aug 12, 2015 01:54 AM
