Injector connectors
Injector connectors
How do these things come off . I have been pulling on them but they dont seem to budge. I have a VG30. Do I have to take off the upper plenum to remove the connectors ? Tehy have never been off before - is that the problem?
Originally Posted by MyGreenMax94
Eat some wheaties...
Seriously though,use a pair of needle nose pliers on the plug release clip..Just be very careful not to break the plug...
So I squeeze the tab with needle nose plies and pull straight up ? I did put a screwdriver to them and listened. they are all ticking in a very healthy way. Is that sufficient indication that they are working or do I have to OHM them out.
the only connector you can remove off vg injectors without pulling the plenum is the #4 (front center) and it's still tricky. The ve is cool because you can get away with buying just 3 new injectors and throwing used in the front because you can replace any of the 3 front injectors in 5 minutes. so you basically save 50% on injectors and still insure you won't have to pull the plenum for a long time. in order to get that peace of mind with the vg, you need to shell out around $600 for 6 new injectors.
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Sep 23, 2015 03:34 PM
