Steering wheel replacement.
Old Jan 31, 2007 | 01:51 PM
Dirt Rich's Avatar
I'm not looking for moral objections to replacing an airbag steering wheel for a non-airbag momo, just someone who's done it before to advise me on how. The only wheel I've ever replaced was like 10 years ago on my old '85 Camaro.
Old Jan 31, 2007 | 02:05 PM
mtcookson's Avatar
If it were me, I'd be ripping the airbag out as well. I don't like them. Actually, I'd take the airbag wheel out, set it upside down on the ground, and set it off to see how high it would fly.
Its actually very easy doing a steering wheel swap like that. You just need the wheel adapter, which if you go to Momo's site they should have an adapter that fits right on to the Maxima. You could probably even go to Autozone or similar and pick up one of the cheaper adapters. I wouldn't be a bit surprised if it would bolt right up.
Most of the aftermarket steering wheels I've seen have a 6 bolt pattern that seems to be pretty standard. I'd get the wheel you want first then check the cheapo kits to see if it fits. If not, get the real deal that works and bolt it up.
Old Jan 31, 2007 | 02:37 PM
Dirt Rich's Avatar
I have the wheel and the adaptor, just never taken off an airbag equipped wheel before and don't want to accidentally set it off or something. How do you remove the airbag mechanism from the wheel?
Old Jan 31, 2007 | 02:41 PM
goon9's Avatar
Just unhook your battery.
Old Jan 31, 2007 | 02:49 PM
Dirt Rich's Avatar
I guess that'd be the most obvious way to avoid an airbag beatdown, but then I still have the issue of the airbag being in the way, blocking me from what's underneath...
Old Jan 31, 2007 | 02:54 PM
Greeny's Avatar
¯\(°_o)/¯
You have to wait about 10-15 minutes for the airbag to become non-functional after unhooking the battery...
The 240sx[non airbag] wheel looks nice on the 3rd gen..
Old Jan 31, 2007 | 02:59 PM
Greeny's Avatar
¯\(°_o)/¯
Here is a pic if a 240sx wheel on the 3rd gen[courtesy of cliff clavin]
Old Jan 31, 2007 | 04:10 PM
Dirt Rich's Avatar
looks nice
Old Jan 31, 2007 | 04:57 PM
marquisdee's Avatar
With the 240 steering wheel, does the cruise control buttons still work?
Old Jan 31, 2007 | 05:28 PM
Pearl93VE's Avatar
I can has?
From what I remember reading, it's Plug And Play.
________
Design Host
Old Feb 23, 2007 | 12:46 PM
Dirt Rich's Avatar
Ok, back to the question. How do you get the airbag off of the steering wheel?
Old Feb 23, 2007 | 01:22 PM
Cliff Clavin's Avatar
Way out West
yes, it works fine, along with the horn. However, mine was a non-airbag car and I am thinking the wiring for an airbag car might be different.
oh, try to use a more recent picture. That one was before I got the AE shift ****.
When I first got the car:
What it looks like now (definitely need a short shifter -- never got around to it):
Old Feb 23, 2007 | 02:56 PM
marquisdee's Avatar
Sweet, I saw a few 240 steering wheels in the junkyard today in real good condition. I love the way it looks in your car.
Old Feb 23, 2007 | 03:02 PM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/showthread.php?t=467798
Old Feb 23, 2007 | 07:05 PM
bvtran's Avatar
94c Big Max
Make sure you disconnected your negative battery terminal first. Take the two split covers off the steering wheel. Look underneath there is a yellow jacket wrapped cable, disconnecting that cable will permanently disable your airbag. I don't know about you but after I disconnected and reconnected it, my air bag no longer functioning. Now all I'm getting is an ugly red air bag warning blinks.
Old Feb 24, 2007 | 04:24 AM
Dirt Rich's Avatar
I won't have to worry about that light at least lol, I already took the bulb out when I changed my guage faces today.
Old Feb 24, 2007 | 04:41 AM
Dirt Rich's Avatar
Originally Posted by MyGreenMax94
Thank you very much, that's exactly what I was looking for.
Old Jul 26, 2007 | 05:03 PM
ColombianMax's Avatar
So I did some searching and found this thread, I just replaced my torn up steering wheel with a 1993 Altima's airbag equipped steering wheel identical to mine but now the airbag light wont go away. What do I need to do to get rid of it and have a functional airbag? Thanks in advance
Old Jul 26, 2007 | 05:18 PM
Never mind, kept searching and found this:
Originally Posted by bhunter
You may need to go through the reset procedure, which as it is previously detailed here before is wrong.
The correct procedure:
Get in the car, leave door open and turn the key to ON but don't start.
Within 10 seconds of turning the key to ON, push the switch in the door frame that lets on the courtesy lights 7 times.
Start the car without turning the key to off first.
Turn the car off and start again.
You may notice that the first time you start the car in this procedure the airbag light still blinks, but slower. The second time the light should go off after the initial lightup and then stay off.
I just tried it and the airbag light did slow down and almost gone but still blinking. For those that have the airbag light on, this is what you should do.
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
