Suspension ?
Suspension ?
Ok..so i was looking at ebay for some lowering springs and found these type...they are call "ZENN". I never heard of that production before..i was just wondering to see if any of you guys have or has try it on their car. Because of right now i need new suspension..my shock just went out and i NEED new springs and shocks..also if anyone has any for sale..let me knoe..i will consider it..i rather buy it from the org then ebay..heres the link to the ZENN springs..let me knoe your thoughts....Should i buy it or not...
http://cgi.ebay.com/ebaymotors/NEW-N...spagenameZWDVW
i saw these a while ago too while browsing on ebay. i think ive seen one max on cardomain that used them.. but i havent heard much about it otherwise. i would also like to know how good a quality these are. isnt tien like a JDM partsource?? thats what ive heard. lol
just curious, if you guys ever use those low rider springs. They will definitely messing up your camber then you will need to use a camber bolt to adjust it. How do you guys even use those things, like how do you hook them up? Where?
Yeah,some of us use "low rider springs".
I didn't need camber bolts for mine,they are a 1.6 inch drop...
The camber bolts go here...
So does that mean that if you have a 2" drop (sprint springs that came with the car) that you need the camber bolts? Is there a way to tell if you need them without getting an alignment done?
If you change a strut, a spring, tie rod, ball joint sometimes or tweak anything. Your probubly need an alingment. Some ppl don't and those are the ppl that b!tch that thier tires wear out fast.
I've done enough work to swapping things in and out to know I got it real close. But I'll still take it to and alignment rack and set them to my specs.
hi, i was wondering if someone can help me out, today i changed my front shocks and springs, i bought kyb gr2s and eibach pro springs, the front is done and is ok, but the back shocks that i bought, did not come with that hat or cup thing that holds the springs like the stock one. and i was wonderin whats the best thing to do? find it and get it welded? fill me in. message here or IM me on Aim : stwodahorty. thanks.
you will need to use your stock housing for the rear. To take that "cup" shape your referring to, you will need to use 2 big pipe wrenches, 5lbs hammer, and wd40:
http://www.harborfreight.com/cpi/cta...emnumber=94067
just so you know, Kyb will not fit perfectly in the rear housing. The cap will not screw all the way down, just tighten it with those pipe wrenches as much as you can. Trust me, it will not loosen over time.
Hey, just wondering... I have a 91' Nissan Bluebird/Stanza. I was looking through the picture of the suspension above and noticed it seems the same as mine. Was wondering if it would actually bolt on, and if there are any after market suspension kits for my car...
Originally Posted by datzvivin02
i ordered zenn springs, hopefully they are satisfying because im just a college student that wants 2 make my 95 pearl white maxima a lil more appealing
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
