New Phenolic Intake Spacers are now available!!
Old Mar 13, 2007 | 07:47 PM
  #81
CapedCadaver's Avatar
Call me Wookiee Goldberg
how long did it take to get the throttle/cruise cables back how you liked? a simple ¼" longer twist-out or did you adjust a few times?
Old Mar 13, 2007 | 08:11 PM
  #82
xx-Marshall-xx's Avatar
kthxbye2u
yeah im going to have to re-tunu my TB cables i didnt do it fully when i got it back on... it needed to be out of the driveway... my step-dads drive way... lol
Old Mar 13, 2007 | 08:25 PM
  #83
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by Gunther
Would you by any chance wanna post the instructions you have made up Aaron, so I know what I'm getting myself into before I say 'gimme one'?
http://www.nissanworks.com/Phenolic_Spacers.html
You can go there to download the Word Document file. Just scroll down a little bit and you'll see it. It's the same full color instructions that I include with every kit!
Old Mar 13, 2007 | 08:26 PM
  #84
Aaron92SE's Avatar
NWP Engineering.com
Yeah, that is one thing I made sure when designing the VE and VG kit. I made sure that the throttle cables will still have the proper tension with the 1/4" TB spacer.
Old Mar 13, 2007 | 08:34 PM
  #85
Aaron92SE's Avatar
NWP Engineering.com
Thank you xx-Marshall-xx for posting those pics! It's so beautiful!!
I just wanted to mention something to everybody. On some of his closeup pictures, you may think that the spacer doesn't follow the outside contour of the upper intake manifold as well as it should. This is because he installed it backwards. But, the ports will still line up perfectly if you flip it over. So he will be fine with it like that. It's just that my spacer kit looks even more pretty when it's installed in the correct direction. It's designed to follow the outside contour of the upper intake manifold, so when it's installed, it looks like it came from the factory like that!
You did good Chris for the first time going into your engine like that! A knock sensor job isn't for everybody! And the very first time you cranked it up, you experienced no intake, fuel or coolant leaks! Good job!
BTW, if anybody needs custom port services, I also offer that. And I will even match your set of spacers to your IM for free with a purchase of a kit.
Old Mar 13, 2007 | 08:57 PM
  #86
Did mine seem a bit .. loose to you or is that how they should be?
Old Mar 13, 2007 | 09:00 PM
  #87
kthxbye2u
And to everyone... the reason i pout it on backwards is because i was using the LOWER intake manifold to set it not the upper
i can fix it... idk if i want to maybe then i can get my upper IM powder coated
Old Mar 13, 2007 | 09:07 PM
  #88
Aaron92SE's Avatar
NWP Engineering.com
Your cables seemed fine. They should be snug while allowing your throttle plate to seat fully. But you are fine. I checked them.
Old Mar 14, 2007 | 04:37 PM
  #89
Gunther's Avatar
Shoulda checked there, thanks Aaron.
Old Mar 14, 2007 | 06:15 PM
  #90
Aaron92SE's Avatar
NWP Engineering.com
No problem. Let me know if you have any questions and I will be more than happy to help you. Thanks!
Old Mar 14, 2007 | 08:08 PM
  #91
maximusve92's Avatar
I am definitly getting one. keep on searching
Old Mar 14, 2007 | 08:12 PM
  #92
Aaron92SE's Avatar
NWP Engineering.com
Let me know if you have any questions. Thank you!
Old Mar 19, 2007 | 05:21 PM
  #93
t6378tp's Avatar
Turbo 3.5
I am sorry, but this kit is made for the VE30DE motor in the 92-94 Maxima SE.
so you do not have any kits for the 95-99 model and if so is the tb spacer thick enough to drill for a nitrous nozzle
Old Mar 19, 2007 | 05:55 PM
  #94
kthxbye2u
its 1/4 inch (0.25inch) ... do you think you can do it?
Old Mar 19, 2007 | 06:33 PM
  #95
Aaron92SE's Avatar
NWP Engineering.com
No, I do not make a kit for the 4th gen. But I can definitely make a TB spacer for the VQ30DE. Someone else mentioned this idea to me.
I still haven't found a 4th gen test vehicle. I haven't had to a chance to conduct my testing in order to find out if a gain can be had with the 4th gen. But I know I can make a throttle body spacer without any problems.
I can make it whatever thickness you need. Send me a PM and we'll discuss it. If there is some interest, then I will definitely make this.
Old Mar 21, 2007 | 08:11 PM
  #96
kthxbye2u
REALLY thinking of taking my car to the track next wensday, that is IF i get used tores on my sawblades and see what the spacers did + the port work you did
Old Apr 12, 2007 | 04:57 PM
  #97
maximamaximus's Avatar
if a kit is avail for 07 model maxima ill be next on the list to purchase it
Old Apr 12, 2007 | 05:11 PM
  #98
Aaron92SE's Avatar
NWP Engineering.com
There isn't one yet. But it's in the works. Please refer to this thread for more details:
http://forums.maxima.org/showthread.php?t=514151
Old May 9, 2007 | 01:54 PM
  #99
mikekantor's Avatar
I haven’t seen this addressed, possibly because it is too obvious to even consider... but I assume these spacers don’t require 2 gaskets on each side, correct?
Old May 9, 2007 | 03:24 PM
  #100
Aaron92SE's Avatar
NWP Engineering.com
No it doesn't. But it does require a proper coating of RTV Silicone Sealant on both sides of each spacer.
Please feel free to read the installation instructions for the VE30DE found at my website:
I still have VE30DE Phenolic Intake Spacer kits left in stock.
Old May 9, 2007 | 11:16 PM
  #101
mszilves's Avatar
Hi Aaron, this looks like a great product, do you still have the longer replacement EGR tube? I don't see it on the site now. We have to pass emissions here in Vancouver. I'm also curious, why do we need to bypass the throttle body coolant?
Old May 9, 2007 | 11:37 PM
  #102
Alex_V
Its part of the gains. The whole purpose of this kit is to reduce temps in the metal parts of the intake system. Hot coolant flows in the TB and manifold heating them up. And the heat transfer from heads to intake also contributes.
Isolate both and theres where you have your gains/resistance to heat soak. There is no negatives to not running coolant through those places though.
~Alex
Old May 10, 2007 | 06:51 AM
  #103
Aaron92SE's Avatar
NWP Engineering.com
No, the VE Replacement EGR tube was discontinued. If you have to pass emissions, you will need to remove the UIM spacer and install the stock EGR tube everytime you need to pass emissions. I have a few people that are in the same boat that have bought VE spacers from me.
Also, the throttle body coolant bypass keeps the TB from heating up. It compliments the spacers nicely. If you leave the coolant flowing through the TB, then the TB and top part of the UIM will heat up hotter than without.
I have never heard of any negative effects of bypassing the coolant even in cold climates. But I'd say, if you are trying to drive your car in subzero temperatures, then leave the coolant flowing through your TB. But, not that many people will try to drive their FWD Maxima when the temps are below 0*F. Many people have driven their cars in single digit temps in the northern states in the US and none have reported any problems.
If you have any more questions, please don't hesitate to ask. Thanks.
Old May 14, 2007 | 01:00 PM
  #104
onyx10's Avatar
im assuming none of these mods throw a CEL right?
Old May 14, 2007 | 03:11 PM
  #105
Aaron92SE's Avatar
NWP Engineering.com
No, none of my products throw a CEL. Even on the VE spacer kit, which has an EGR Block Plate, it doesn't throw a code. Some VEs have an EGR temp sensor and no CELs appear also. Just make sure you specify if you have a California model Maxima or if you have an EGR Temp Sensor that must be bypassed in order to block the EGR system.
Old May 14, 2007 | 05:44 PM
  #106
Big_E-Dog's Avatar
2nd Gen Boostinator
how thick are those spacers???
Old May 14, 2007 | 08:54 PM
  #107
todamax's Avatar
Installed mine the other day. Easy install. I don't have any opinion yet though as I haven't driven the car.
Its still in pseudo storage from winter. I'll pull it out at the end of the month....
Old May 15, 2007 | 08:10 AM
  #108
Aaron92SE's Avatar
NWP Engineering.com
They are 1/4" thick.
More information can be found at: www.nissanworks.com
Old May 15, 2007 | 08:57 AM
  #109
DanNY's Avatar
Ad·min·is·tra·tor
~Alex
i thought in extreme cold the TB plate will have the tendency to stick...hence the warm coolant temps will expand the alum TB housing to prevent that.
if there wasn't a reason for the coolant to pass through the TB and bypassing would gain HPs why wouldn't nissan implement it?
so IMO there is a negative affect not running coolant though the TB but only in very cold conditions.
Old May 15, 2007 | 10:05 AM
  #110
ustfdes's Avatar
- Product of Maxima.org -
Definately a mod i will be buying in the near future!
love the presentation, and the positive responses from your customers. as soon as life settles down a bit, i'll drop you some funds.
Old May 15, 2007 | 11:24 AM
  #111
Aaron92SE's Avatar
NWP Engineering.com
That's great. I appreciate everyone's support. I have several kits left in stock. The VE kits aren't nessecarily flying off the shelves. There are very few people on this forum that want to mod their 15 year old Maxima. But the people that do like to mod them have a VERY nice sleeper on their hands.
Old May 15, 2007 | 11:29 AM
  #112
ustfdes's Avatar
keep a kit in stock for me....by near future i mean about 2 - 4 weeks
how many have you shipped so far? i'm suprised they're not more popular.
Old May 15, 2007 | 03:10 PM
  #113
Aaron92SE's Avatar
NWP Engineering.com
I've probably sold 5 or 6 kits so far.
You gotta keep in mind, most people that have a VE are still in school and poor. And the rest aren't really interested in making it faster for some reason.
Old May 15, 2007 | 09:10 PM
  #114
ustfdes's Avatar
odd....i'm pretty poor, and in school (intermittently) and love to make my car go faster, and run better. :x VE5 <3
Old May 16, 2007 | 08:28 AM
  #115
Aaron92SE's Avatar
NWP Engineering.com
Join the club! No matter how poor someone is, if they are willing to work on a project car themself, you can make it faster for cheap.
Old May 20, 2007 | 09:36 PM
  #116
magobiasso's Avatar
guau!! i want it!!!
Old May 21, 2007 | 07:33 AM
  #117
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by magobiasso
guau!! i want it!!!
I can ship anywhere in the world. Just email me your address for a shipping quote.
XXXaaron@nissanworks.comXXX (Remove the X's)
Old Jul 4, 2007 | 01:08 PM
  #118
NismoChi's Avatar
Any changes on that ? I am ready to purchase set but really don't want to take it all out every two years to pass emission or so.
Old Jul 9, 2007 | 08:04 AM
  #119
Aaron92SE's Avatar
NWP Engineering.com
No I am sorry. The tube was discontinued.
But, every two years isn't bad at all. In most areas effected by emissions, it's every single year.
I apologize for the delayed response, but I am out of town right now. I sent you a PM reply.
Old Jul 9, 2007 | 11:08 AM
  #120
Jeff583's Avatar
Im sure it would not be really difficult to customize your own down pipe if you need it to pass emissions.
