Flywheel lightweight
Hey my flywheel is going out. How do i know? Cuz everytime i start my car (especially when its cold) it grinds until it catches. Sounds most unplesent and is only unmatched by fingernails on a chalk board.
Where do i get a light weight flywheel for a good price?
I see www.srmotorsports.com has one for $300
Now that im replacing it i figure i might as well get a lightweight Aluminum flywheel.
This sucks cuz i should have just kept the one on there from the JDM engine but now that i remember i think it was damaged but ill go look today.
Sugestions or comments?
Its not the starter.
its Most likely not your flywheel.. its probably your starter.. Theres a oneway bearing that is going out in it... it starts to happen alot when it gets cold out.
happened to me.. and i thought i needed a flywheel for sure.. but it turned out to be the starter. thankfully
I have an automatic.
Ok well it could very well be my starter and I really hope it is. BUT why I say it isn't is because it was doing this a few months back when it started to get cold out so i replaced the starter with a reconditioned one from Autozone and its still doing the same thing. It was an easy install so i dont think i messed it up.
Autozone sold me a crap caliper so they might have screwed me again.
So how do i know for sure.
2.The starter should have a lifetime warranty,so take it back to idiotzone..
3.Stay away from idiotzone from now on..
4.If it turns out your flexplate teeth are worn/missing,i have a good used one for sale ...
wow same thing happeing to me, so i swithed my starter from my extra car, and it is ok, but had a diffrent issue. but i cant wait till i get a clutch and alum fly installed it has to be nice
Hey so i went to auto zone with my recon. starter and they said they are supposed to check them before they send em out the door
i said "that wouldah been nice" so i got em to swap me starters but this time they tested it, everything looks good....for now.
Thanks for the help!
i said "that wouldah been nice" so i got em to swap me starters but this time they tested it, everything looks good....for now. Thanks for the help!
Yeah flywheels don't really "go out". They typically would have to break teeth to cause trouble or you'd have to wear down just about every tooth to have a starting problem. And I imagine that would take many a year. My starter is acting up right now pretty badly too. I'm sick of winter's tricks.
KabirUTA13
19
Oct 17, 2015 02:15 AM
