Engine probelms...
Old Feb 22, 2007 | 12:11 PM
raeqwon28's Avatar
Engine probelms...
I have a 91 Maxima that I recently put in a new engine in. I got the engine with 50,000 miles on that was a import from japan. I got everything hook and check all the vaccum lines and stuff but i'm still having trouble starting it sometimes and when do I get it started I have no power to get up a hill. I'm contemplating on taking it to mechanic or actually selling the car as is. I want to know from you all on how much you think I might get from selling it or should I get a mechanic to trouble-shoot my probelm?
Old Feb 22, 2007 | 12:35 PM
Jbr8k's Avatar
More info?
How are the injectors,fuel filter/lines,cap rotor, plugs/wires,starter,manifold studs.
Check the stickies for info on how to run an engine diagnostic for trouble codes.
Old Feb 22, 2007 | 12:40 PM
Jbr8k's Avatar
Quote:
Originally Posted by mtcookson
turn the screw clockwise and wait for the leds to flash 3 times then turn it back counter clockwise. this is the diagnostics mode. from here the leds will flash individually indicating the code. the red led indicates the 10's and the green led indicates the 1's. i.e. if the red led flashes 2 times and the green led flashes 3 that would be code 23.
Sounds like you do it a little different than I do. Turn the key to the "ON" position. Then turn the little screw on the ECU clockwise, wait for 2 seconds, then turn it back counter clockwise . Then the red light will flash in 2 sequences. Slow flashes indicate the first digit of the number, Fast flashes will indicate the 2nd digit of the number. Say it goes "flash....flash....flash...........flash.flash.fla sh....." That would be a code 33 which is o2 senor. If there are no codes in the ECU it would read 55. Turn the screw counter clockwise, hold it then turn it back to the original position.
There you go.
Old Feb 23, 2007 | 04:43 AM
raeqwon28's Avatar
Okay, appreciate that. I'm going to run the codes again and see what the probelm is.
Old Feb 23, 2007 | 06:24 AM
maxitech's Avatar
It shouldn't be too hard to diagnose if you put enough time into solving the problem. First thing, post ALL the relevant info you have. We can help you rule out things from there.
Old Feb 23, 2007 | 06:51 AM
Alex_V
Did you put a tuneup on the engine? Does it sound like its missing at idle? Did you check your timing?
Tell us more about how it acts. Since it runs and drives shouldn't be too hard.
~Alex
Old Feb 23, 2007 | 07:32 AM
DanNY's Avatar
Ad·min·is·tra·tor
sounds like timing is really off or like Alex said it needs a tune up
Old Feb 23, 2007 | 08:00 AM
mtcookson's Avatar
There you go.
Probably a different ecu, VE maybe?
The way I described was for a 90 VG ecu but I know the VE ecu was a little different in the overall design so that could be it.
Old Feb 23, 2007 | 08:32 AM
DanNY's Avatar
Ad·min·is·tra·tor
91 = VG..no?
Old Feb 23, 2007 | 10:29 AM
mtcookson's Avatar
Jbr8k has a 92.
Old Feb 23, 2007 | 10:56 AM
ColombianMax's Avatar
I'm DanNY on the timing and with Alex on the tune up.
Here's a lil vid Alex and I made on timing that might help you. You may need it if you dont know how to adjust the timing so dont think I'm just assuming you dont know anything automatically.
Hope it helps!
http://forums.maxima.org/showthread.php?t=508818
Hope it helps!
Old Feb 23, 2007 | 08:03 PM
Chris Gregg's Avatar
Get Off My Lawn
I'm not sure what the hype still is with JDM engines. My experience is that they are crap and beaten to death. I second opinions. They also suggest that you tighten heads and do compression checks before installing any used engine. I'd also check vacuum hoses as cold weather brings out the worst in our rubber hoses. This will make the car difficult to start and idle as well. These symptoms get me every winter and I know to start checking hoses, especially the tiny one that runs to the heater coc on the firewall.
You swapped over all sensors? I've been told that the JDM electronics are not compatable with US. Although I have not compared them, Nissan shop foreman told me this.
Old Feb 23, 2007 | 08:15 PM
mtcookson's Avatar
WTF dude... everyone should know JDM engines make at least 100 hp more than US engines...
For those that don't know, I'm just kidding. I think most people get them due to low mileage but, as you said, they tend to be in bad shape even with the low mileage. The JDM VG30ET I got wasn't the greatest. Ran good and everything but the coolant passages were dirty as hell. I've cleaned it out numerous times and my heater core still gets clogged. Yet another good reason for me to go back to my Maxima block.
Old Feb 23, 2007 | 09:11 PM
Get Off My Lawn
My coolant system was same way. Glad I ended up having the block dipped/cleaned out!
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
