my max keeps cutting out. help!
Old Jul 8, 2001 | 12:34 PM
blaxima92
It does it about every time I drive it. It'll be running fine then all of a sudden the engine will cut out kinda like I've let off the gas but I haven't, then it will stop doing it and the cars runs fine untill it does it again. It usually only lasts a few seconds. And when it does it everything else in the car stays on (radio, lights, ect) What do you guys think is wrong? I was thinking the fuel pump or something to do with the fuel line. tell me what you think. thanx
Old Jul 8, 2001 | 01:27 PM
nubiannupe's Avatar
OG Maxima.org Member
Well, first I'd ask if you lost COMPLETE power when this happened (i.e., radio, lights, etc...). If not, then I'd look at the fuel delivery system. Heaven forbid if it's the injectors. You're on the track, too, by thinking that maybe it'll be the filter, pump, or fuel lines. But has this always happened, or has it just started to develop over time.
Old Jul 9, 2001 | 08:33 AM
blaxima92
Well it used to do it before but it only did it a few times and now it does it all the time.
Old Jul 9, 2001 | 02:06 PM
MadMaxBrent's Avatar
Have you checked for any fault codes?
Brent
Old Jul 9, 2001 | 06:04 PM
blaxima92
Do yoou mean is the service engine light on? If that's what your talkin about the answer is no the service engine light is not on.
Old Jul 9, 2001 | 06:15 PM
You can also get the ECU to run a diagnostic. There may be some faults that don't show up as "Service Engine" - I don know for sure if this is true or not. Do a search to find out how to run a diagnostic just to confirm there are no fault codes.
Brent.
Old Jul 11, 2001 | 08:06 PM
blaxima92
Well I don't have a ECU or whatever.
Old Jul 11, 2001 | 08:27 PM
dmontzsta's Avatar
Ford Only.
Check your Catylic Converter.I had the same problems I replace so much shi* I dont even want to get into it.But trust me to make a long story short and avoid any costs take your car and have the Cat checked it wont cost too much.I couldnt beleive it I kept letting my car cut out and it got worse and eventually wouldnt even drive.
Old Jul 11, 2001 | 09:06 PM
Actually you do. I am referring to your cars ECU.
Brent.
Old Jul 13, 2001 | 02:33 PM
german eater's Avatar
Blaxima,
I experienced similar issues with my 92 SE. It would be driving fine and then start bucking and the engine would cut out, but all the electronics still worked. My problem also started to get worse as time went on. Nissan couldn't fined anything wrong but suggested that I check the ENGINE CONT relay under the hood (mounted in the relay box on the drivers side fender). Sure enough, after replacing the relay my car was back to normal. If any of these problems sound familiar pick up a relay they are only about $20.00. The Engine Cont relay supplies power to your ECU ,so if its bad, it is clipping the power to your ECU causing these symptoms to occur.
shilov
Feb 19, 2024 09:40 PM
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
