pacesetters short throw shifter
Old Mar 12, 2007 | 10:44 PM
elusivemax93's Avatar
for those who asked if they still where being made well i found the pacesetters website and found that they do indead still make there short throw shifter and have contacted them to find out how much each one would cost or where i could find a dealer that sells them here is the site
http://www.pacesetterexhaust.com/quikshift.php
Old Mar 13, 2007 | 03:11 PM
jbeau's Avatar
i have one sitting around.. it's missing the ball tho...
Old Mar 15, 2007 | 06:12 PM
maxitech's Avatar
Step 1: Remove stock shifter assembly
Step 2: Heat in oven
Step 3: Hold shifter rod in vice, move ball down on rod w/vice grip or similar tool
Step 4: Rinse, lather, repeat...
Old Mar 16, 2007 | 06:24 AM
mtcookson's Avatar
The pacesetter is crappy enough that it'll probably drive you to gouge your eyes out with it. Yeah... its that bad.
Old Mar 16, 2007 | 06:38 AM
maxitech's Avatar
Let me explain (to those who don't already know) why it is just as affective to modify your stock shifter as opposed to buying an aftermarket one...
The only difference between stock and aftermarket is the position of the ball on the shaft...THAT'S IT!!! So don't waste your money...Not only that, but most of the aftermarket shifters for 3rd gens have been described as feeling "notchy."
Take my advice on this one...Michael is the one who clued me in on doing this, and I really like the results...
Old Mar 16, 2007 | 09:40 AM
Hollywood!'s Avatar
how long/what temp did you put it in the oven for? (im just curious)
Old Mar 16, 2007 | 10:30 AM
maxitech's Avatar
400 degrees F and...say 10 minutes at first. It cools quickly so be ready to get to work as soon as you take it out.
Michael, did I miss anythng???
Old Mar 16, 2007 | 10:33 AM
Michael's Avatar
Back in a 3rd Gen.
Yeah Matt told me about it a while back.
Hollywood!...just turn up the oven high and let it cook for a while. BE WARNED that you will need some welders gloves and even then you will probably have to wrap some other things around it to keep from burning yourself. The best thing to do is have the vise ready...cook it and take it out with some tongs or something and put it on the vise...move the ball and you are good to go after it cools.
http://forums.maxima.org/showthread.php?t=480401
http://forums.maxima.org/showthread....ry+short+throw
Old Mar 16, 2007 | 11:12 AM
maxitech's Avatar
Dang, Michael...I didn't heat mine up NEARLY as hot as you say...Then again, I had to attach vice grips to the ball and whack it with a rubber mallet.
Old Mar 17, 2007 | 10:55 PM
juggalo_g's Avatar
eh just chop you stock shifter down same some money i did and it feels much better
Old Mar 18, 2007 | 06:42 AM
Michael's Avatar
Back in a 3rd Gen.
umm its easier to do what Maxitech said with the stock shifter...besides just chopping the stock shifter doesn't give you a STS shifter...it just gives you a shorter shifter.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 31, 2015 02:04 AM
atriuum
Sep 28, 2015 01:19 PM
