Bleeding Brakes?
Old Jul 9, 2001 | 07:21 PM
JDwyer2821's Avatar
I just changed my rear calipers and got a little air in the system and the brakes dont really work. How hard is it to bleed the brake system? What would a mechanic charge?
Old Jul 10, 2001 | 03:46 AM
TerribleTed
Get a Haynes or Chiltons. Read the brake bleeding part. Get a Friend and a 6 pack of your fav. beverage and go to it. It is really easy. You will need a bit of fluid, a CLEAN jar and some hose of the proper size (in the Haynes or Chiltons manual)
The basic procedure runs like this.
Disable ABS by removing a fuse (See Manual)
put one corner of the car on a jack stand
remove the tire
Pump up the brake pedal
place hose on bleeder, dunk other end of hose into a clean jar about 1/4 filled with NEW brake fluid. (keep that end submerged)
With your friends foot on the brake pedal Open the bleeder valve with a wrench just a little bit, let fluid come out. You will see air bubbles if there is air in the system.
Close the bleeder. Add more fluid to the master Cylinder.
Pump up the brake pedal again until it is firm.
If there were bubbles repeat until there are no more bubbles.
Do this for all 4 corners in the order specified in the manual.
If you don't have friends you can pick up a set of Speed Bleeders.
BTW removing the tire is optional, but it makes it easier to get to the bleeder valve.
Old Jul 10, 2001 | 10:14 AM
maxmizd27's Avatar
remove the tire
You can get a hand operated vacuum pump at most parts stores that runs around $25 and includes everything you need (tubing, adapters and cup). No "buddy" necessary. You pump it through the line right at the brake caliper. No pedal pumping! Works great.
Additionally, I would start with the longest line, which is typically the right rear corner, first. Go to the left rear next, then the right front and finally the left front. This keeps any air from back flowing into other lines and wastes the least fluid.
Old Jul 11, 2001 | 10:02 PM
Tick Tock's Avatar
And, don't forget to be careful with that brake fluid... It will take the paint right off your car.
I prefer Valvoline Synpower DOT3/DOT4. Do NOT USE DOT5 synthetic - it is incompatible with DOT3/4 and can cause serious problems.
Old Jul 12, 2001 | 05:07 AM
TerribleTed
A little cheap AutoXer secrete... Ford heavy duty DOT3 fluid is excellent stuff. What happend is little old people in their Crown Vics would ride the brakes and boil fluid, then complain that the brakes weren't working right. So Ford made up a new DOT3 for them, called it Heavy Duty and that fixed the problem. It is cheap, it is good stuff and you can get it at your local ford dealer by the caseful.
Old May 30, 2002 | 07:48 PM
superdesi's Avatar
What is the dealer cost for this fluid?
Old May 30, 2002 | 09:33 PM
ThurzNite's Avatar
so what's the fsm say for the order of bleeding? and if you've got one of those vacuum bleeding things, does your car have to be on?
I've spilled brake fluid on the inside of the engine compartment trying to fill the reservoir...no paint loss yet.
Jae
Old May 30, 2002 | 10:42 PM
mykizism's Avatar
Jae
rub it, 100% the paint will peel right off
Old May 31, 2002 | 05:21 AM
«§»Craig B«§»'s Avatar
Jae
you always do it in the order furthest away from brake reservoir to closest
since our reservoir is in the front left, do RR,RL,FR,FL
Old May 31, 2002 | 11:47 PM
ThurzNite's Avatar
well, i'd try, but it was on my old 93 altima which got into a hit and run so we don't have it anymore.
i can't rub it...otherwise i woulda wiped it off in the first place. at the time, i forgot that it washes off with water. oh wells.
so does the car need to be on when you're bleeding clutch or brakes?
Jae
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
