Fuel fillup shutoff
Old Apr 3, 2007 | 03:45 AM
redwood_usa's Avatar
Fuel fillup shutoff
I used to be able to insert the fuel nozzle,start pumping at high volume, put the holding latch on and wait by the side till the gas tank was full and the pump shut off. Now, at multiple gas stations, the fuel shuts off as soon as I start pumping at high volume. I have to manually hold the nozzle at low volume to fillup the gas tank. Any one have any ideas on what may be causing this.
Old Apr 3, 2007 | 06:09 AM
Josh's Avatar
It just happens sometime, mine does it rarely. Just try moving the nozzle around and it might fix it.
Old Apr 3, 2007 | 09:16 AM
Tried it - doesnt work. Happens at different pumps.
Old Apr 3, 2007 | 09:26 AM
VEvolution's Avatar
I miss my VE
Thats weird.. I thought it only happens if it's not in all the way or your full.
Old Apr 3, 2007 | 09:54 AM
92 Max's Avatar
Could be the vent tube is clogged or crushed. It runs alongside the filler tube and allows air to exit the tank when filling and prevents the gas from "burping" back up the filler neck and shutting off the pump.
Old Apr 3, 2007 | 12:24 PM
Prophecy99's Avatar
same damn thing happend to me on saterday !!!?? and i was holding it manually and it cut it off like it was full 3 odd times.
Old Apr 3, 2007 | 01:13 PM
92 Max's Avatar
If it just happens once or at one gas station it usually means that the nozzles at that station have a hyper active shut off. They can adjust this and some stations are worse than others. I've had it where you have to hold the trigger on the nozzle full time to get any gas in the car, then I had another station that I don't go to anymore where the nozzle wouldn't shut off and would spray your shoes with gasoline every time.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
msellas
Sep 23, 2015 09:16 PM
