broken lug stud repair?
how do you guys repair broken lug stud for the front wheel without removing the hub? The back round water shield was in my way so I wasn't able to press it backward. It looks like I have to remove the hub to get to it but doing that might damaging my new wheel bearing which I don't want to go thru it again.
Here is the picture of that round water shield I referred to:
p.s. that's a old picture, please disregard the wheel bearing works.
Originally Posted by bvtran
how do you remove that round dust shield because that thing was in the way for me to press out the broken stud?
if not get a dremel and make a notch around the part where the caliper goes.
thanks guy, I'll cut a small portion off that shield so I could stick in a socket to press it out.
therealgoon9,
you said the shield felt off after you cut it off. Does that means after you took it off, then dust shield can not be reused right?
Is it possible I could cut it off enough so I could get a new stud in without discarding the the entire dust shield? I think it's crucial to have it there to limit debris from getting into the wheel bearing area.
therealgoon9,
therealgoon9,
therealgoon9,
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
mkaresh
Mar 12, 2018 06:48 PM
