Control arm bushings
Will this fit my 93' gxe. i cant find es bushings for a 93'.
7-3111
$ 35.00 from http://www.suspension.com/nissancars.htm
Or should I be buying them somewhere else.
Also, all instructions I see state that I should remove the large ball joint nut and take the balljoint out with the control arm. Any views on removing the three lower bolts instead and leaving the ball joint on the hub.
7-3111
yes those will work.
you do need to modify them though.
A little search will yield lots of information
Is this the best place to buy poly bushings?
Any opinions on this part.
doesn't matter much which way you do it. But if your bushings are bad chances are so is your ball joint
that's why I sell the complete arm with the bushings and ball joints more often than the Bushings OR ball joints alone
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
