replacing piston rings
Old Apr 21, 2007 | 07:43 PM
JakeDilingo's Avatar
how hard is it to do, and how much would i be looking to spend if i had a shop do it? VE motor...
Old Apr 21, 2007 | 07:59 PM
Jon94SE's Avatar
Depends how much you know about motors and/or hands on experiance. Not very hard to do if you have the right tools and an engine stand. My guess is a shop will rape you for $$$.
Old Apr 21, 2007 | 08:57 PM
internetautomar's Avatar
mod or sell?
It's probably the most labor intensive job in the motor.
it's not hard to do, just takes lots of time.
Old May 15, 2007 | 01:51 PM
bonez_tmac's Avatar
Once you can set the timing (which is a REAL pain in the a$$) it really isn't that hard. I can walk you through it if you want. It will talk anywhere from 12-18 hours for you seeing that this is your first time.
Old May 15, 2007 | 06:30 PM
Cliff Clavin's Avatar
Way out West
If you are going through the trouble of replacing the rings, you might as well do a lot of other stuff, too.
You would basically be taking apart the engine, so you might as well upgrade some things.
I know a really good mechanic in Meridian, but I don't think he would work on an import.
Old May 16, 2007 | 04:25 PM
car looks good and runs fine, spent alot of time and money on it. I can do alot of things mechanically, but never taken a motor apart. put in a clutch before but thats propably the longest job, not the hardest, Ive done. I think Im going to just live with it, im sure the rings are worn but its nothing noticeable other than the extra carbon buildup. I'm going to do minor maintenance and keep it as long as it runs, then sell it and buy a new maxima...if I ever see a VE-5 with good VTC i'll be all over it, swap all my stuff over, then turbo it. ima keep dreaming tho. thanks guys
Old May 17, 2007 | 04:07 PM
maxmaxima91's Avatar
how many miles on the engine?
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
TheMafia
Sep 4, 2015 08:26 AM
