fuel pump problems
Old May 6, 2007 | 07:24 PM
grinder's Avatar
fuel pump problems
I just swapped the motor in my 89 se and tried to start it up... nothing. so I checked the fuel lines to make sure that it is getting gas, it wasn't. I then put the fuel pump from the donor car that I had gotten the motor out of, which ran great but didn't have a title, and still nothing. I checked the fuses, they were good, then I traded the fuel pump relay from inside the trunk, and that didn't help, it still does not work. I know for sure that the fuel pump worked out of the donor car because I have drove that car. I don't know what the problem might be from here, and I was hoping that one of you guys might have had a similar problem and might have a solution for me.
Old May 6, 2007 | 08:22 PM
plaman88's Avatar
god damn fuel pumps in these things! i just left hell with mine. Double check the fuse, mine kept feasting on it. Did you cut into the wiring at all anywhere? The relay was tested good elsewhere? Are you getting any codes?
Old May 7, 2007 | 07:31 AM
grinder's Avatar
My fuse is just fine, it has not blown out at all. I double checked everything and it all seems to be in order.
I was wondering if it could be my anti-theft device and if it is how to get around it, the local shop wants more than I paid for the car to just see IF that is the problem.
Old May 7, 2007 | 07:46 AM
internetautomar's Avatar
mod or sell?
do a quick search on anti-theft and you'll find the location of the box.
just unplug it and done
Old May 7, 2007 | 07:50 AM
grinder's Avatar
ok, then that kinda shot my idea down, that box is unplugged.
Old May 7, 2007 | 08:06 AM
ghostmax's Avatar
check the fuel pump harness under the back seat to see if it is melted/corroded. mine was and caused a no-start symptom and bad hesitation on load. if the plug is fine, then check the voltage at the fuel pump to see if it's getting any power.
Old May 7, 2007 | 08:59 AM
Alex_V
If you have aim I can help you next time I'm online. If you don't get it figured out lmk, I'm just over an hour away from you (I live in columbus)
~Alex
Old May 7, 2007 | 09:15 AM
grinder's Avatar
~Alex
cool, I might take you up on that offer if i cant figure this out soon. I don't have aim btw. I have been working bugs out of this car for 11 months now and it is just getting a bit frustrating.
Old May 8, 2007 | 09:43 AM
grinder's Avatar
well, I got the fuel pump working!! I fired it up and it died, so I tried to start it again and it won't fire. I'm just having all sorts of good luck with this project. I don't understand why it won't fire, I changed the wires, coil, distributer, and none of that helped. Any suggestions?
Old May 8, 2007 | 09:54 AM
Greeny's Avatar
¯\(°_o)/¯
Do you have any wiring/other parts of the engine "jury rigged" in any way?
Old May 8, 2007 | 10:03 AM
ghostmax's Avatar
have you checked the harness/wiring of the fuel pump?
Old May 9, 2007 | 10:10 AM
grinder's Avatar
Nope, I put this together the right way, no shortcuts(that has been most of the problems i have been having, trying to find somebody that will help w/o rigging and having "extra" parts). But it is kinda seeming that my problems may be in the relays now, would that possibly make it quit firing?
Old May 9, 2007 | 10:14 AM
grinder's Avatar
About the fuel pump, my problem there was that one of the pumps I was using was bad and when we tried the good pump we had a bad relay in it, so we finally go that issue resolved, but thanks for the suggestions. Now I am having problems getting the engine to fire, after I got it to run, it died and wont fire now.
Old May 9, 2007 | 12:48 PM
92 Max's Avatar
If you're getting proper fuel flow and pressure, next is to check for a good spark.
Old May 10, 2007 | 10:55 AM
grinder's Avatar
ok, as soon as I get back to the car that is exactly what I will do. Thanks.
Old May 12, 2007 | 05:01 PM
grinder's Avatar
Quite a few ppl told me that hooking my car up to the computer and reseting the cars computer would fix my problem with the engine not firing, I was just wondering if this could be the solution that I have been looking for(before dishing out $175 to have it done). Has anyone else heard of anything like that?
Old May 12, 2007 | 05:11 PM
Greeny's Avatar
¯\(°_o)/¯
Quite a few people were wrong.....
Old May 12, 2007 | 09:37 PM
LvR's Avatar
LvR
+1
Old May 13, 2007 | 11:04 AM
grinder's Avatar
I have checked and double checked everything else so I guess the last thing I can do is try to run the codes on it, I was told that running a jumper on the diagnostic port beside the fuse panel from port 1 to port 9 with the battery unhooked and when you hook the battery back up and turn the ignition on it will run through the codes and tell what relay or sensor is bad if there is one. Is that how you do that.
BTW thank all of you for all the help you guys are giving me, much appreciated
Old May 13, 2007 | 11:22 AM
Alex_V
Um try that if you want a fried ecu. I think that only applies to some domestics. Check the stickies for the proper way to pull codes!
~Alex
Old May 20, 2007 | 09:28 PM
magobiasso's Avatar
already adjustment the problem?
Old May 21, 2007 | 07:43 AM
grinder's Avatar
I just pulled it to the side and I am going to save up and take it into the shop later, let the pros handle it, I have tried everything that I can think of and cannot figure it out.
Thanks for all of your help though guys, it really helped me out alot.
Old Jan 6, 2008 | 04:47 PM
jmichaelrush's Avatar
Wondering if I have a fuel pump problem here.
Symptoms:
The car will run fine if not under load(and sometimes if it is under load), but occasionally if I gun the gas, the engine will all of a sudden just cut off. Weird thing though is I can let off the gas and press in the clutch for about 2 seconds and the engine will turn back on. It feels almost as though the gas flow can't keep up with the injectors.
Old Jan 6, 2008 | 05:12 PM
jonmandude's Avatar
I had a similar problem. It turned out to be the relay for the ECU under the hood.
Old Jan 7, 2008 | 11:57 AM
What is the ECU. I am assuming it stands for Electronic Control Unit, but I can't find that in the FSM. All I see is the ECM.
Oh, side question: Can I use the 1994 FSM?
Edit: Realized I just posted a stupid question about the FSM seeing as it is still a 3rd gen VG dur dur dur
Old Jan 7, 2008 | 12:04 PM
mod or sell?
1. ECU = ECM
94 FSM covers all VE motors and all VG A/T models. it does not cover VG with a M/T though.
Old Jan 7, 2008 | 12:57 PM
BenStoked's Avatar
Jesus was a Zombie.
it does cover all ve manuals, in case you didnt quite get that.
itll work for my car mostly, until i get tranny problems...
BkGreen97
Apr 2, 2016 05:47 AM
RWCreative
Sep 21, 2015 11:01 AM
rnb754
Sep 14, 2015 11:39 PM
conansriver
Sep 11, 2015 10:26 AM
