when spark pluge wire are dead
Old Jul 12, 2001 | 04:36 PM
89MaxGXEStock's Avatar
when one of the spark wire are dead does the car shake when put into drive and doesn't in neutre. If it is what brand should i get. I want performance kind.
Old Jul 12, 2001 | 04:50 PM
Jeff92se's Avatar
I'm needing a caw
OEM Nissan wires are very good quality and will serve you well. They lasted until now correct? But I believe msd and others make quality plug wires also.
There are many things(including a bad wire) that will make your car shake in drive(ie.. loaded,low rpm condition). That is not an accurate way to diagnois that problem. But it's a good way to start. If you supect a particular wire, you can check them individually for ohm resistance readings. Or while the car is idling, you can undo one wire at a time. If the car does not run worse when you pull a particular plug, it could be that wire, plug or dist cap point.
Need help
23
Oct 2, 2015 08:56 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
