bad lifters?
Old May 10, 2007 | 12:50 PM
mooze's Avatar
bad lifters?
well when i start my car theres this light knock and a squeak with acceleration. think its a lifter a but not sure. if it is does anyone know how to replace them or stop it from squeaking.
Old May 10, 2007 | 01:38 PM
xx-Marshall-xx's Avatar
kthxbye2u
squeaking is prolly from a loose belt alternator would be my guess
second... the knock... check your oil maybe... change the oil
and fixing them... that would be a general question
Old May 10, 2007 | 01:41 PM
Jeff92se's Avatar
I'm needing a caw
Prolly the dist cap.
Old May 10, 2007 | 02:22 PM
ColombianMax's Avatar
Mine is doing the same, think my coils are going bad
Old May 10, 2007 | 02:50 PM
kthxbye2u
hey has a VE guys...
Old May 10, 2007 | 02:52 PM
you mean he
Yea, and I got coils
Old May 10, 2007 | 06:13 PM
Greeny's Avatar
¯\(°_o)/¯
The knock is most likely the vtc,s clacking at startup..
The squeal is a loose/worn out accessory belt..
Maybe you need to take this car to a qualified mechanic to get all your issues fixed,instead of starting a new thread everytime you find a new knock/clack/squeel/clunk/hiss/shimmy/etc....etc....etc...
Old May 10, 2007 | 07:10 PM
kthxbye2u
remember he grounded them?
Old May 10, 2007 | 07:29 PM
Greeny's Avatar
¯\(°_o)/¯
I grounded mine 3 years ago...They still clack a little at cold start up...
Old May 10, 2007 | 09:34 PM
mooze's Avatar
yeah. could be them. the alternator belts not squeaking i just replaced that and its pretty tight. could be belt going to compressor. how do i tighten that
Old May 10, 2007 | 10:06 PM
mooze's Avatar
im in the process of buying a replacement engine but before i get ut u want to see if i can do anything with this one. doesn't look like im going to have dat much progress so time for the replacement
Old May 10, 2007 | 10:58 PM
Well if its too tight you can damage the bearing on the alternator pulley. therefore wear down the belt and make noise.
Old May 11, 2007 | 09:19 AM
92 Max's Avatar
Also, If you grounded your VTCs and it still clacks it may be the timing chain tensioner.
Old May 11, 2007 | 02:55 PM
kthxbye2u
INDEED INDEED!!!!!
Old May 13, 2007 | 10:12 PM
mooze's Avatar
vtcs or timing chain not sure which 1 but not really caring. just going to replace the whole thing
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
