Camber Kits with Intrax Springs
Old May 20, 2007 | 07:40 PM
nForce's Avatar
The Computer Guy
Does the camber kit brand matter with certain springs? I bought Intrax springs off an org member and he was sayin cambers is need because front tires bow out. Would OBX Camber Kit work fine?
http://cgi.ebay.com/ebaymotors/OBX-C...QQcmdZViewItem
Old May 20, 2007 | 07:44 PM
Greeny's Avatar
¯\(°_o)/¯
I wouldn't do camber bolts...
http://forums.maxima.org/showthread.php?t=519286
Old May 20, 2007 | 08:00 PM
James92SE's Avatar
2 VE's are better than one!
I'm sure they'll work fine. I think someone was saying a few years ago that they're all just rebadged Ingall's or something rather.
Anyway, I've been running camber bolts on my Intrax for about 5 years with no problems. They've never moved on me or come out of spec, but then again I dont autocross or run over curbs daily.
Old May 20, 2007 | 08:01 PM
nForce's Avatar
The Computer Guy
so those ebay OBX should be fine?
btw: what kind of struts have you been running with your intrax? I have kybs and just curious if they will last a year on intrax.
Old May 21, 2007 | 02:22 PM
GRNMAXDMON's Avatar
http://forums.maxima.org/showthread.php?t=517345 <--- go there to look for your answer on springs/shocks setup.
Old May 21, 2007 | 02:51 PM
goon9's Avatar
Never had a problem with my camber bolts... Altough if I were to do another alignment I would do what matt said in that thread. Maybe even bore out the hole and reinforce the opening somehow...
Old May 21, 2007 | 02:59 PM
nForce's Avatar
The Computer Guy
so what else is there to use besides camber bolts? Im guessing no one uses kyb with intrax
Old May 21, 2007 | 03:08 PM
Greeny's Avatar
¯\(°_o)/¯
I have a 1.6 inch drop[almost the same as intrax's 1.7 inch] and i do not have any issues with abnormal tire wear...
You should be fine without any camber adjustment...
Old May 21, 2007 | 03:12 PM
nForce's Avatar
The Computer Guy
Well I can give it a try I dont have anything to lose my tires are about dead so who cares
Old May 21, 2007 | 03:29 PM
Greeny's Avatar
¯\(°_o)/¯
Tires are Everything when it comes to handling.
Old May 21, 2007 | 03:53 PM
Michael's Avatar
Back in a 3rd Gen.
intrax will kill KYB in no time. I had brand new ones and PA said they were dead in no time after getting the car.
Old May 21, 2007 | 06:49 PM
nForce's Avatar
The Computer Guy
can I still drive the car with blown struts?
Old May 21, 2007 | 06:50 PM
nForce's Avatar
The Computer Guy
I thought they were 1.7 Front and 1.5 Rear?
Old May 21, 2007 | 06:54 PM
James92SE's Avatar
Intrax are 1.75" all around and you'll most definitely have some extremely negative camber with them. Will kill your tires in no time - dont waste any time getting the bolts in and aligned
Old May 21, 2007 | 06:56 PM
nForce's Avatar
The Computer Guy
So is there another kit besides camber bolts?
Old May 21, 2007 | 07:12 PM
James92SE's Avatar
Not other than the custom style goon9 pointed out
Candiman actually had a set of camber plates fabbed up years ago but they didnt pan out IIRC
Old May 21, 2007 | 07:17 PM
nForce's Avatar
The Computer Guy
ok so OBX Cambers will be fine? http://cgi.ebay.com/ebaymotors/OBX-C...QQcmdZViewItem
If so I will buy these now. I got the springs cant wait to install them.
Old May 21, 2007 | 07:28 PM
James92SE's Avatar
Yep, go for it. That's a good price
Old May 21, 2007 | 07:30 PM
nForce's Avatar
The Computer Guy
ok sounds good im gonna buy them now. How long should it take to install new springs? 4 hours maybe?
Old May 22, 2007 | 03:34 AM
Greeny's Avatar
¯\(°_o)/¯
According to the intrax website they are 1.7 front/1.5 rear..
http://www.intraxsuspension.com/productSearch.asp
I thought they were 1.7 all around..
Old May 23, 2007 | 01:29 PM
GRNMAXDMON's Avatar
what camber bolts are you using? what are the specs?
Old May 23, 2007 | 02:13 PM
James92SE's Avatar
I'm using Specialty Products EZ Cam Xr bolts #81250
www.specprod.com
Old Jun 18, 2007 | 07:52 PM
'93maximaGXE's Avatar
where can i get some tokico struts and intrax springs at a low price? dont flame, i cant find any that fit on ebay.
Old Jun 18, 2007 | 07:56 PM
exub's Avatar
[caps]SPONSORS FORUM WOW[caps]
Old Jun 19, 2007 | 05:37 AM
Greeny's Avatar
¯\(°_o)/¯
http://cgi.ebay.com/ebaymotors/TOKIC...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/INTRA...spagenameZWD1V
http://www.autopartswarehouse.com/pe...=203&year=1992
http://www.sfxperformance.com/parts/INT601015.htm
These prices are about as good as it gets for new struts/springs..
Old Jun 19, 2007 | 02:05 PM
ColombianMax's Avatar
Hey Wayne I have GR-2's and want Eibach so they last me a bit longer than with intrax, wanna find me some on ebay too?
Apr 16, 2020 05:15 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
