quick helpe removing o2 sensor
Old May 21, 2007 | 02:42 PM
4thgradedropout's Avatar
so..i thought i new how to remove my o2 sensor but i was wrong. i have a 92 gxe is there a right up on how to remove it? i sold it and need to get it out.
Old May 21, 2007 | 02:47 PM
goon9's Avatar
Vise grips, hammer, 1 margarita, 2 wacks, margarita salt if your the type, and done.
Old May 21, 2007 | 02:59 PM
Greeny's Avatar
¯\(°_o)/¯
A write up to remove an o2 sensor?
Wheaties/Wrench/lefty loosey...Done..
Old May 21, 2007 | 03:05 PM
ok i guess it is that easy.....ill fiddle with it
Old May 21, 2007 | 03:07 PM
redwood_usa's Avatar
Liquid wrench the night before, warm up the car a bit (2 mins) then follow instructions above
Old May 21, 2007 | 03:08 PM
nForce's Avatar
The Computer Guy
You live pretty close if you need help I can come over its super easy to take off. I did mine last year took about 30 mins
Old May 21, 2007 | 04:11 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i did mine too with a pair of roll-on ramps, a wrench, and however much time it took the engine running to line up with the ramps and get the car up them (was tough to baby the throttle to get up them and not roll off the end when facing downhill)
unfortunately i still get the ECU code for it, so i probably have a bad wire somewhere as well.
Old May 22, 2007 | 12:56 AM
maximagician's Avatar
you can undo the harness before spinning loose the sensor body
so the wire dont twist . the plug is mounted into the rear of the crossmember by the rear motor mount and the wire is push snapped into the crossmember too
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
Stelianos
Aug 19, 2015 02:07 PM
kirkhilles
Aug 8, 2015 10:53 AM
