Cleaned up the Engine a Bit Today
Old May 23, 2007 | 07:29 PM
maxitech's Avatar
I was under the hood of teh ole' VG today and did a few things...
1) Replaced several hardened vacuum lines
2) Cleaned IACV (with TB cleaner, I think)
3) Cleaned MAF (with MAF cleaner)
4) Cleaned MAF plug, TPS plug and a few other misc. plugs with electrical aerosol cleaner
5) Inspected cap and rotor / took some fine grit sand paper to the contact points
6) Diagnosed injector #4 as the culprit of my car not running perfect about half of the time...parts on the way
7) Sprayed engine bay down with engine cleaner and hosed it off
8) Discovered it is going to be a real PITA to replace my whiny P/S pump when I get around to it
Tomorrow is wash day...Clean and Scotchguard interior, wash, claybar, apply cleaner wax, and apply wax (all top-shelf Meguires) to my car.
Next weekend I plan on taking the car to my buddy's shop about 75 miles from here to get the paint work done...Then she'll look cherry!
Old May 23, 2007 | 07:35 PM
Greeny's Avatar
¯\(°_o)/¯
Nice pics......
Old May 23, 2007 | 07:39 PM
maxitech's Avatar
Originally Posted by MyGreenMax94
Nice pics......
You know what a VG engine bay looks like...and I haven't got it as clean as I do want it, yet. (It gets dirty way too fast w/o splashguards.) Besides, I plan on buying a proper digital camera over the weekend, so rest assure I will be taking pics...
Old May 23, 2007 | 07:41 PM
Greeny's Avatar
¯\(°_o)/¯
Just razzin ya dude..
Old May 23, 2007 | 07:45 PM
maxitech's Avatar
I know...
Funny thing is, the car seems faster when the injector wants to work...I don't think it's in my head...Just by replacing 4 or 5 lines and cleaning a bit of dirt and corossion.
Old May 23, 2007 | 07:54 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah,my injector kept going in and out randomly...
Old May 23, 2007 | 08:42 PM
maxitech's Avatar
Only had one fail, eh?
Old May 24, 2007 | 04:03 AM
Greeny's Avatar
¯\(°_o)/¯
Yeah,#1 cylinder...
Old May 24, 2007 | 11:08 AM
Mr.Davon24's Avatar
DAQ wouldn't the water harm the wire harness?
Old May 24, 2007 | 11:46 AM
Alex_V
No. Ive power washed both my car's engine bays and nothing bad has happened. nForce does his all the time, and his car is fine.
Just let everything dry off and don't get water in the alternator directly and you'll be fine.
~Alex
Old May 24, 2007 | 12:12 PM
traxtar944's Avatar
Would be lost w/out the org
you mean the distributor block? Yes, it could....just cover it with aluminum foil or a towel while spraying down and you should be all good, though.
Old May 25, 2007 | 08:20 AM
Alex_V
No I meant the alternator....Ive always heard it can kill the alt if you spray it directly and some times if you just splash it. But that was from mostly non-nissan guys, maybe our alts are made better...
~Alex
Old May 25, 2007 | 09:33 AM
mikekantor's Avatar
You could always pull out a leaf blower to quicken the drying, or a can of compressed air to get water out of small areas.
Whenever I do maintenance or repair, I tend to take some extra time to clean around that area while its all apart. For most parts, acetone does amazing work, and its cheap. I just soak a bit of a paper towel with it and rub lightly, all gunk and oil buildup comes off almost instantly. Just be careful with plastics and painted areas.
Old May 25, 2007 | 09:39 AM
Greeny's Avatar
¯\(°_o)/¯
I use a leaf blower to dry my engine bay..I especially concentrate on the sensor/other electrical connectors,works great..
I also get a laugh out of it when the neighbours look at me like
Old May 26, 2007 | 01:00 PM
SButlerNC's Avatar
so it wouldnt hurt 2 pressue wash engin bay?
Old May 26, 2007 | 01:05 PM
Pearl93VE's Avatar
I can has?
*sigh*....
CorollaULEV
30
Aug 9, 2021 08:11 PM
raffivegas
Aug 23, 2015 09:54 PM
Trin1j23
Aug 12, 2015 08:31 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
