engine tranny change
Old May 25, 2007 | 07:07 PM
cspangg's Avatar
Gents, I'm changing my engine a nd tranny on a 92 GXE SOHC AUTO. I'm changing the cam seals , crank and rear seals . Any suggestions on the BRAND to use. I'm also changing the oil pump with a Melling( Anyone has any feedback on melling oil pumps and any lessons learned
Old May 26, 2007 | 01:40 AM
Greeny's Avatar
¯\(°_o)/¯
Unless you just like your automatic,you might want to swap out the auto for a manual transmission..
Get all the seals from the dealership,less chance of getting the wrong parts,and they are as cheap or cheaper than the major chain auto parts stores..
No clue on the oil pump..
Old May 26, 2007 | 07:51 PM
internetautomar's Avatar
mod or sell?
get the little seals at the dealer, the price difference is minimal.
Melling is a well respected manufacturer of oil pumps, so you won't go wrong there.
Old May 30, 2007 | 08:38 AM
cspangg's Avatar
what little seals are you refering to?
Old May 30, 2007 | 08:39 AM
mod or sell?
front crank and cam seals.
Old Jun 1, 2007 | 02:20 AM
bigdanny's Avatar
can the sohc engine use a manual tran? i heard from somewhere only dohc can use stick...
Old Jun 1, 2007 | 03:26 AM
Hectic's Avatar
Just shows how screwed up information can get as it gets passed through the vines. The guy probably was trying to say the GXE only came with an automatic and SE was available with a 5 speed, which is true. Course prior to 92, the SE had the SOHC motor. Search for 5 speed swap and find loads of information on how to convert your GXE a 5 speed. Basically you just get all the parts from a 5 speed SE and bolt it up to your car. Splice a couple wires too.
Old Jun 3, 2007 | 09:09 AM
cspangg's Avatar
engine tilter
Gent's, trying to remove engine/tranny. What bengine tilter and hook up points did you use and do the intake manifold have to come off/////////???
MAXSE5SPD
Sep 17, 2022 04:00 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
RealityCheck
Aug 5, 2015 06:18 AM
