View Poll Results: which one?
Rear VTC
18.92%
Rear exhaust studs
19
51.35%
Oil pan seal
10.81%
Other
18.92%
Voters: 37. You may not vote on this poll
Most annoying "engine-in-car" job?
Old May 29, 2007 | 08:55 AM
mikekantor's Avatar
I'm in the middle of the rear VTC one, it spilled over from this weekend so the work continues. That chain tensioner just wont go back in!
If you’ve done these or consider doing any of them in the future, what’s your opinion on the “PITA”-ness of the work? I'm still looking forward to the other two.
Edit: I should've mentioned, if you say Other, please elaborate... it would be great to know what you managed to do.
Old May 29, 2007 | 09:39 AM
92 Max's Avatar
Yeah the rear tensioner is a pistol to get aligned, since the only thing that aligns it is the bolts. If you have the front tensioner in place, pay attension to the angle it and the engine is at. That's what I had trouble with. The angle that seems correct is actually off from where it needs to be. Try also giving yourself some slack in the chain by turning the cams slightly with a 24mm wrench.
Old May 29, 2007 | 09:53 AM
mikekantor's Avatar
I did the front a while ago so I dont remember visually how it was placed. The tensioner is under the chain, but yeah the bolts are not aligning correctly. I've been giving it the slack, but that has left me with only one hand to awkwardly align the bolt with... spent about 1 1/2 hours on that last night before quitting, more tonight but I'll probably get a second person to lean on the wrench this time.
Old May 29, 2007 | 11:25 AM
todamax's Avatar
Man, I had no issues with that....
Old May 29, 2007 | 11:57 AM
92 Max's Avatar
Yeah, I dragooned my wife into helping.
Old May 29, 2007 | 12:13 PM
Josh's Avatar
Yep the rear is a pain, if i remember correctly I put one bolt in and then rotated it to get the other in place.
But from all I have heard I would think that the rear studs would be the biggest PITA.
Old May 29, 2007 | 03:55 PM
todamax's Avatar
If you guys are having issues with that little tensioner, try doing a clutch in a 944 sometime. You will want to light it on fire and walk away.
Old May 29, 2007 | 06:27 PM
heresmymind
head gasket. HehE
Old May 29, 2007 | 06:39 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by heresmymind
head gasket. HehE
Said your mechanic..
Old May 29, 2007 | 06:45 PM
heresmymind
(said me biaaaaaaaaaaaoooootch)
Old May 30, 2007 | 06:07 AM
maxitech's Avatar
broken rear studs FTL
Old May 30, 2007 | 06:12 AM
mikekantor's Avatar
front or rear head gasket? either way... touché.
I finished with the blasted thing last night around midnight, couldn't start it though because the battery is down to 7V and the way the car is situated I cant get jumpers to it. Then I came up with the plan to shift into neutral and roll it off the ramps so I could connect, but its stuck in park (laugh it up 5-speeders). Today I should be able to get another set of cables, connect both for one long cable, and resuscitate the VE.
The poll result of the rear exhaust studs being worse is not making me look forward to it, either way I'll most likely be doing that sometime in July.
One more thing, I have discovered something interesting on the car, something I like to call the Maxima Abyss. This is the space into which all the missing bolts, clips, and small tools fall into, never to be seen again. It cannot be spotted with the naked eye, nor will a flashlight help. This space is between the crossmember and the rear engine mount, go check yours now I'm sure you'll find something!
Old May 30, 2007 | 06:19 AM
Greeny's Avatar
¯\(°_o)/¯
Got any pics?
Old May 30, 2007 | 07:22 AM
heresmymind
Originally Posted by MyGreenMax94
Got any pics?
nope. i do have a scar from the job. does that help?
Old May 30, 2007 | 07:53 AM
Josh's Avatar
Shift lock release?
Old May 30, 2007 | 08:41 AM
mikekantor's Avatar
Originally Posted by Josh
Shift lock release?
Im not too familiar with the shift lock system beyond just a layman awareness of it, and it was too late to deal with it last night so I just let it be. I'll search around a bit and try to get a clue though.
Old May 30, 2007 | 09:12 AM
Josh's Avatar
Its the little button at the base of the shifter.
Old May 30, 2007 | 09:28 AM
mikekantor's Avatar
Oh I messed with it a little, didnt seem to do anything, I may just need to press harder.
Old May 30, 2007 | 09:31 AM
heresmymind
if u have enough battery power to hav interior lights on. turn ur key all the way like it would be on. push in brake. and shift.
Old May 30, 2007 | 09:35 AM
mikekantor's Avatar
First thing I tried, didnt work. There was marginally enough power to move the seatbelts.
I had a failing starter that drew a lot of power and killed the battery. Its off in the mail for a warranty repair now, I just popped in a junkyard starter and jumped it to get the car in the garage so I could start work, but the battery did not have enough time to charge up.
Old May 30, 2007 | 10:29 AM
Josh's Avatar
Yeah, just push that in and hold the shift button and you can shift.
Old May 30, 2007 | 07:53 PM
mikekantor's Avatar
Shifted to N so easy, its even written right there! I must have been really exhausted the first time to miss something so obvious.
Engine seemed a bit lazy during the first test drive, then I flipped the tiny little round nozzle on the top-rear of the plenum and VRROOM, the thing is like a rocket now, cant even imagine how well it will run after the rear studs are fixed.
Old May 31, 2007 | 12:40 AM
maximagician's Avatar
whatchu talkin bout willis?
Old May 31, 2007 | 06:34 AM
mikekantor's Avatar
I'll try to get a photo of it today, but maybe a description will help anyway. At the rear of the plenum there are 3 vacuum hookups IIRC, 2 large and 1 small diameter. The small one is at the top. Out of it, a short hose comes and meets this tiny nozzle/valve, and out of there goes into something else, I don't remember what. I've also never seen this nozzle/valve on any diagram.
This nozzle/valve does not let any air into the plenum when the plenum tries to draw air in, but it will open if the plenum tries to push air out. I just dont know what its overall function is.
If you run the car, take off the hose (its not on tight) and it will start to run like crap, then put your finger over it to block incoming air and the engine will be fine again.
I've never seen a VG up close so as far as I know this only applies to the VE.
Old May 31, 2007 | 08:41 AM
92 Max's Avatar
I've never seen a VG up close so as far as I know this only applies to the VE.[/QUOTE]
Is this the small (~1/8") nipple at the top back of the upper intake plenum? This is the the vacuum tap for the heater water valve. That's the unit clipped to the firewall behind it. This hose goes through a one way valve then plugs into the water valve.
Old May 31, 2007 | 09:01 AM
mikekantor's Avatar
Yeah, sounds like thats the one.
Old May 31, 2007 | 07:31 PM
Maximan190's Avatar
i did all three of those things...
Old May 31, 2007 | 07:41 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
it's called a water **** solenoid. i was trying to find a vaccuum leak on my car (haven't found it yet...) but that's one of the places i looked. it's part of the hot/cold system that allows coolant flow into your heater core when you switch over to heat. FSM page HA-65
does anyone know if it's a really bad idea though to just pull off hoses like that? aren't you letting unfiltered air into your engine?
Old May 31, 2007 | 07:45 PM
Greeny's Avatar
¯\(°_o)/¯
It wont hurt the engine to unplug vacuum lines while it is running,unless you are stuffing dirt into the vacuum line while it's off..
Old Jun 5, 2007 | 10:22 AM
Matt93SE's Avatar
STFU n00b!
I got you beat....
fit that fat beotch in there and get it running..
Old Jun 5, 2007 | 10:26 AM
mikekantor's Avatar
yeah Matt, checkmate.
Is this an old pic, or something you're doing now while also moving?
Old Jun 5, 2007 | 10:45 AM
Matt93SE's Avatar
STFU n00b!
nah.. that's last summer.
I was putting my rebuilt VE in, and I had the VG30DE leftover from a customer's engine swap... I thought I'd put it in there for grins to see if it would actually fit in the hole.
it *did* fit, but the thing had so much crap on the front of it(water pump and accessory drive are HUGE on it) that I couldn't line up the engine mounts- leaving no room for a transmission. there was also so little room on the sides of the engine, it would have been nearly impossible to hook up any of the hoses and wiring, which are all hidden on the sides and bottom of the intake manifold.
Old Jun 5, 2007 | 02:26 PM
xx-Marshall-xx's Avatar
kthxbye2u
VG30DE is a negatory
Old Jun 5, 2007 | 03:03 PM
dead2fall's Avatar
... wow thats pretty huge looking
psss **( thats what SHE said )**
Old Jun 8, 2007 | 09:10 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
ut uho a lotta ppl will have to eat their words of a vg30dett being stuffed into a maxima...
do yous got room for turbos in there or is it tight?
Old Jun 9, 2007 | 08:38 AM
Pervis Anathema's Avatar
Are you high?
Old Jun 9, 2007 | 08:45 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
a lil
a lil
Best response ever.
James92SE
142
Jan 2, 2024 09:23 AM
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
